Old 06-18-2008, 09:12 PM
dneisler is on a distinguished road
Milling a peice of steel
I am needing to mill 1/4" off a peice of steel, no idea what kind.
My part is 2" x 2" square. I was thinking of using my trusty 2.5" face mill.
What DOC? .01?
What RPM? 1000?
What FeedRate? 5 IPM?
I have never touched steel before with my mill(X3) so I really have no idea.
***For full up to date details visit my blog @ www.donald-neisler.com
Donald Neisler
Old 06-19-2008, 06:36 PM
Limited660 is on a distinguished road
I would say roughly 500-800 rpm(this is including 500%-800% increase for carbide inserts) but I could be wrong since ive never done it for indexed cutters. You can go .025 maybe more with carbide but I wouldnt go past .050 a cut and I have no idea on feed rate.
Old 06-20-2008, 03:44 PM
stovepipesteve is on a distinguished road
a good speed and feed formula.
3.82 X SFM X DIA. OF CUTTER = RPM
RPM X # OF INSERTS X LOAD PER TOOTH = FEED
3.82 is a fixed number
SFM can be found on insert card or cutter info.
3.82 x 450 x 2.5 =687rpm (sounds safe)
as far as feed, i dont know your insert #, load per tooth,,about .002-.003 sounds safe.
Milling steel with IH mill? Rich05 Industrial Hobbies (Support forum) 14 07-04-2008 06:59 PM
Need Help!- Milling my first steel parts.... dneisler General Metalwork Discussion 1 04-30-2008 11:18 AM
Great peice of software freddean2006 SheetCam 0 12-04-2007 04:29 PM
bending of steel after milling dhiruj General Metalwork Discussion 17 03-23-2007 03:29 PM
help! peice problems abomb55076 Moldmaking 10 07-28-2006 04:35 PM
