Old 06-11-2008, 07:54 PM
Reg wharton's Avatar
Reg wharton is on a distinguished road
drillng 302 stainless steel
I,m drilling a 13/32 dia. hole 1.88 deep. What's the best drill to use? I would also like to know speeds and feeds.
thankx
Old 06-12-2008, 02:15 PM
g-codeguy is on a distinguished road
Mill? Lathe? Coolant? Coolant pressure?
Old 06-12-2008, 05:56 PM
302 stainless
I'm using a lathe with plenty of coolant and pressure.
Old 06-12-2008, 08:11 PM
Does it have a Fanuc type control so you can use a macro deep drilling subprogram? Sorry for not asking this earlier.
Old 06-13-2008, 05:27 AM
I,m using a nakamura with fanuc control.I'm new to this machine.I have tried g83 but only throws an alarm.The other guys in the shop say this machine does not support drilling cycles.I find that hard to believe.I will research this and try to find some kind of manual on this machine.Right now the program is written out the long way(this program was used last time they ran the job).
Thanks for the reply
Old 06-16-2008, 06:07 PM
Paul V is on a distinguished road
Reg have you tried cobalt drills at a slow speed. I have drilled ss with tin coated drill at a slow speed. You can also drill harder steel with a concrete dill bit , regrind the angle on it
as you would a metal drill bit.
PaulV
Old 06-16-2008, 11:28 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
solid carbide is your best bet if your running production , if you weigh the cost against the time saved ,you may find you've saved money
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 06-17-2008, 04:38 AM
shay z is on a distinguished road
try iscar's camdrills. you will get the carbide replaceable cutting bit with the flexibility of the HSS drill.
Old 06-17-2008, 05:58 PM
Thanks for all the input fellas, I ended up going with solid carbide. I started with a high speed drill that took 3 min./pc. Now I'm turning 2300rpm @ .006 ipm. It now takes approx. 15 sec.
Thanks again for all your help.
Old 06-17-2008, 06:55 PM
Carbide is definitely the way to go if it holds up. Our lathes haven't any coolant pressure higher than about 135 psi. Not the best for drilling holes that deep without an additional peck or two. One shot normally blows them up in short order. Although I've been told you shouldn't peck with carbide drills, that is the only way to make them last for us.
Drilling is where the most time can be saved. It doesn't pay to go cheap. Maybe one of the reasons we can't drill this deep in one shot is our purchasing agent buys the cheapest drills he can find. He gets a bigger bonus the more he saves on tooling.
Stainless steel larry53 General Metalwork Discussion 4 04-22-2007 11:32 PM
Steel or Stainless tool_man Casting Metals 2 10-29-2006 05:46 AM
Stainless Or Steel 69owb Mechanical Calculations/Engineering Design 5 10-03-2006 01:43 PM
Stainless Steel ? Depoman General Metalwork Discussion 2 01-12-2005 05:40 AM
Is stainless steel CNCadmin Hard and High Speed Machining 12 10-17-2003 08:19 AM
