Old 06-10-2008, 01:14 PM
ecotectoo is on a distinguished road
F&S for 353 brass
I'm pretty new at machining and have only done wood since we've gotten our CNC router a few months ago. Next week I'll be doing our first metal project: cutting out some parts in .032" HH 353 brass sheet.
I've Googled around but can't seem to find anything on F&S for small cutters or drills. I'm planning on using a 2-flute upcut .0394" diameter cutter and .065" diameter drill. My machine's slowest speed is 6,000 rpm.
Suggestions for F&S? Ramp down or plunge? Should I do the thickness in two cuts or one?
I also would like to engrave the part numbers on the pieces but need some sort of automatic height- (or force-?) adjusting cutter (my table is out a few thou and the waste board varies slightly). The only one I can find is the 2L tool which is both too long and very expensive.
Other suggestions?
-- Rich --
Newbie- Make your own Brass? MidFloridaTech Casting Metals 7 05-11-2008 09:28 AM
Newbie- Weld Brass to Brass piratesover40 Welding, Brazing, Soldering, Sealing 3 03-03-2008 06:02 PM
Brass...why? creative_mind General Metalwork Discussion 2 05-25-2004 12:27 AM
How can I cut Brass? cbcnc General Metalwork Discussion 3 01-13-2004 07:54 PM
Where to buy Brass? NeoMoses General Metalwork Discussion 3 10-05-2003 08:35 PM
