Hi All, I'm running a bunch of small jobs in brass which require a lot of cutting with a 1/32" end mill. I'm having pretty good luck with these parameters, but I'm breaking end mills if I run any faster: 0.03125" diameter 4-flute HSS mill 0.0625" long 4500 RPM (max) 30% of tool diameter cut depth Flood coolant 0.000125" chip load 2.5 IPM feed Does this seem slow? I hate to experiment and break tons of mills... How would you trade cut depth vs feed rate for a little mill like this? Thanks! -Bill |
| Thanks -- what's the thinking behind the 2-flute? I don't think I'm getting much clogging of the flutes with the brass, and the 4-flute end mill should be stronger and allow me to run twice as fast... Cheers, -Bill |
| You can increase the feedrate because you'll have more room to eject chips. 4 flutes are stronger, made for harder materials where you cut a lighter chip load. A 2 flute HSS is perfect for what your doing. Good luck! MC |
| help with speed and feed carbide end mill | alex 850 | Bridgeport and Hardinge Mills | 9 | 12-26-2007 11:10 PM |
| Home made cross slide power feed for small lathe | monte55 | General Metal Working Machines | 3 | 12-16-2007 01:30 PM |
| Feed and Speed for 3d profiling with small tools? | Loading | General Metalwork Discussion | 4 | 11-03-2007 04:41 AM |
| Small end mills feed speeds for 1mm steel | paulr4 | DIY-CNC Router Table Machines | 12 | 08-13-2006 07:29 AM |
| EMCO FB-2 Mill - need power feed? | brassman1 | Benchtop Machines | 0 | 11-04-2005 11:18 AM |
