Old 06-05-2008, 05:16 PM
G-code is on a distinguished road
Long tool. Speed and feeds recommendations
Hi guys,
I'm in a tough spot right now. I'm tryning to machine a 2.000 counter bore, 2.5 deep. The C'bore seats on the bottom of a part 5.500 tall. Therefore the end mill sticks out 5.625' out of the endmill holder. I'm using a 1.000' indexible end mill. The shattering is too much and the finish is very bad. Here's my current S&F:
S: 2750
F: 10.0
Axial depth: .120
Radial depth: .875
Old 06-05-2008, 06:03 PM
fuzzyracing1967 is on a distinguished road
You don't say what the material is but just cut your numbers in half,or just start by slowing your speed,sounds like the tool needs more of a bite.Oh and thats not a long tool by any means,just today was working with a two foot core drill and borring bar.
Just push the button,what's the worst that could happen.
Old 06-06-2008, 02:01 PM
thanks fuzzy. I forgot to mention it's aluminum. After some trial and error I changed to the following:
S 3500
F 36.
Axial depth: .046
Radial: (same) .875
yeah I'm using more depth cuts but I increased my feed so it's about the same cutting time as the previous confuguration.
I'm sure in the future where gonna start buying bigger and longer tools. My bosses are seeing the diference.
Thanks again.
P.S.What 67? a VW bug?
Tool database,speed and feeds and Shop floor document preperation blmmdes Hypermill 4 04-09-2008 12:51 AM
3D Profiling EN24T - Speed & Feeds Davidimurray General Metalwork Discussion 1 10-12-2007 06:46 AM
Need 3-axis CNC vertical mill recommendations <$10k (Long post) PCS74 General Metal Working Machines 9 03-08-2006 12:38 AM
Speed and Feeds problems Tazzer General Metal Working Machines 1 09-17-2004 07:03 AM
Speed Controller recommendations? paulried DIY-CNC Router Table Machines 2 05-13-2003 05:39 AM
