Old 06-04-2008, 12:03 PM
ohioengr is on a distinguished road
cnc software
I am looking for a quality cam product for a 2 axis lathe(hitachi seiki)I used smartcam at previous employer but not to happy with the support.Mastercam seems alot better!Anyone have any recommendations?
Old 06-04-2008, 12:11 PM
chrisryn is on a distinguished road
Just from experince using esprit, mastercam, smartcam, gibbscam, easycam, edgecam.
Go with Edgecam. They all have there pros and cons but edgecam is my favorite, mastercam is the popular one, its what I used till I found edgecam.
No matter how good you are, there is always someone better!!!
Old 06-04-2008, 01:22 PM
you used smartcam and mastercam ,how easy was it to switch from smartcam to mastercam?I used smartcam for 5 years ,in the late 90's and now I want to use mastercam.Will the change be confusing?
Old 06-04-2008, 01:24 PM
I started with mastercam and then dabled in smart cam. So I won't be much help I tought myself mastercam. The local votech had smartcam and I messed with it for about 2 days before giving up. I don't know if that awnsers your question but thats about the extent of it.
Old 06-04-2008, 08:01 PM
ctate2000 is on a distinguished road
I would buy tools with the money and write G-Code in MS Notepad.
Old 06-05-2008, 07:31 PM
Delw is on a distinguished road
I've used smartcam since the early dos versions, both for lathes and mills. I tried mastercam surfcam and a bunch of others and it took me a long time to learn and I still suck at it. I am sure if I started on mastercam or something else it would be just the same to switch.
Smartcam support is pretty darn good, they also have a email list and you get support from 20-30 guys on every question you have. that to me is unbeatable. not to mention tons of tips and tricks.
2d milling on smartcam or any software should be pretty easy to learn however
Old 06-06-2008, 03:09 PM
Dr Pete is on a distinguished road
Yep, Machining a part right now that no program would handle.
Buy good quality tools and a G-Code book
Old 06-06-2008, 05:52 PM
JROM is on a distinguished road
EXXXXXXXXCUSE ME!
TRY PROGRAMING A 3D SURFACE MODEL WITH YOUR G-CODE BOOK!
I'D LIKE TO SEE THIS PART THAT NO CAM SYSTEM COULD HANDLE!
BULL!!!!!!!!
Be carefull what you wish for, you might get it.
cnc software grebator General CNC (Mill and Lathe) Control Software (NC) 1 05-01-2007 05:38 PM
First post in the software dept. Free cnc software? runinbymdnt General CNC (Mill and Lathe) Control Software (NC) 2 02-06-2007 09:49 PM
What software are you using? cwdance1 General CNC (Mill and Lathe) Control Software (NC) 6 01-26-2006 05:07 PM
CAD Software kellogs72 General CNC (Mill and Lathe) Control Software (NC) 5 12-30-2004 06:36 PM
