Old 05-22-2008, 01:29 PM
antelnation is on a distinguished road
Chip Removal with Compressed Air
Hi everyone,
I am fairly certain this question/need has been addressed before but I am having trouble finding it on cnczone. I want to "hook up" a compressed air line to my little Taig mill so that I don't have to constantly blow out chips manually.
Is there a old thread that explains how to do this? Or can someone tell me how to do it? Or is not feasible to do in my garage (i.e. Do you need a really expensive air compressor.)?
Attaching the air hose close to the cutter seems easy enough but I am not sure what type of air compressor would be suitable/ideal for this application.
Or maybe there is an easier method to accomplish my goal of automated chip removal?
Can someone help me out? Thanks-Josh
Old 05-22-2008, 01:52 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Go ahead.
Use small diameter tuning (3/16 OD) and install an inline flow control to adjust the airstream with.
Then get yourself a $100 compressor to run it with.
Bear in mind that these inexpensive compressors tend to be noisy and have a limited duty factor.
Better yet would be to use an air mist system, to lube and cool your cutter as well.
www.integratedmechanical.ca
Old 05-22-2008, 04:20 PM
shadrag is on a distinguished road
Some have had luck with aquarium air pumps (not the cheapo ones), much smaller and quieter than a cheap compressor. I may go this route after I get a little more cnc experience.
Old 05-22-2008, 06:20 PM
tikka308 is on a distinguished road
I show exactly how I did this with my TAIG mill here - http://www.nyccnc.com/Herbie/HERBIES...ompressor.html
Tormach PCNC 1100, SprutCAM, Alibre CAD
Old 05-23-2008, 01:44 PM
wwendorf is on a distinguished road
I did something a little different. I took a mag base that I found that was for oil lines. I just added a few adapters to it, hooked it up to my compressor, and wa-la! I had adjustable air nozzles. I'm no longer using them anymore as I went to the fogbuster system.
You can order them here: http://www.shars.com/products/view/1...nt_Hose_System
In addition, if you want a place to buy tooling pretty cheap that works good (at least everything I have bought works good) check out this tooling company. www.shars.com
Cheers!
Wade
chip removal by vacuum sucking rajanish Safety Zone 14 03-22-2011 09:37 AM
PVC Compressed Air lines Five-10 CNCzone Club House 47 01-07-2011 07:51 AM
Chip to Chip Time Gene0552 General Metalwork Discussion 36 09-01-2010 11:05 AM
Compressed air filter/regulators wildcat Metal Working Tooling 5 06-30-2007 07:29 PM
Compressed air supply required for 50A plasma.. hotponyshoes CNC Plasma and Waterjet Machines 13 04-15-2007 08:16 AM
