We are using spiral flute taps for both through and blind holes. Through holes have worked out pretty well so far, blind holes have not. Recently we used a FEW M8 tap. We tapped close on 200 through holes into Mild Steel. The next job had blind holes. On the first hole the tap broke. We drilled 30mm deep and tapped 25mm deep. It broke when it was at the bottom of the hole. I know there could be many causes but it is stange that we continually break taps on blind holes.... ![]() Any suggestions as to what we are doing wrong, or is this just the expected lif of the tap. The supplier claims that the tap should do approx. 400 holes. |
| Taps are hardened, therefore brittle. A tap will ALWAYS break if it hits the bottom of a blind hole. You must drill deeply enough to prevent this--Bearing in mind that the hole depth needs to be deeper than you think. A certain percentage of the bottom of the tap is a ramp for starting and does not actually thread. CR. |
| You did not mention what material you are cutting or your tap drill size or your lubircant or your tapping speed or your peck increment. Even when I tap 1018 steel, which is easier than most, I have learned to drill .005"-.010" bigger than the chart says for blind holes and spiral flute taps. That reduces the torque significantly. So I would use a J letter drill (.277") for an M8 blind hole 30mm deep. I would use Tap Magic with EP, and tap .400" the first time, .700" the second time and .980" the third time, all at 300 rpm or less. Maybe even four pecks, especially if you drill smaller. I used to try to save 10 seconds on another pass and lose an hour re-running the part. Also, a hi performance tap is great even with mild steel. One that can handle stainless can handle most other materials. Email me at davereagan@hotmail.com if you need a lead on good taps or parameters for another grade of steel. |
| Weastone - You can not use spiral fluted taps for blind holes Unless you have enough clearance at the bottom for the chip to go. You need a tap that pulls the chip up. Lock at this PDF site from JEL - look for a tap called "Tarex" I will check if there is an English site. But the taps are available in the US. I am sure you can find one from a US supplier. http://www.jel.de/kataloge/a1_dt_n.pdf Could not find it in English, but scroll down a few pages to " Gewindebohrer - Sacklöcher" and you will find "Tarex" for different materials listed on the left. It shows you a picture of the tap that will give you an idea what to look for. As you will see - the flutes are designed to bring the chip to the top. Looks like JEL is part of the "Komet" group. Here is the website - http://www.kometgroup.com/kometgroup/DE/home.html You can call Komet to find out where to buy JEL taps. We found they have the best selection for any type of hole and material. Last edited by juergenwt; 05-21-2008 at 12:14 AM. |
do you have sufficient coolant pressure to remove the chips from the holes after drilling , you may need to add an M0 in order to blow the chips out of the hole with the air hose , if you have high pressure thru spindle coolant then put the tap in an er collet ,it will help to clear the holes davereagan brought up a good point about the drill size , the machinist handbook will show you the max hole dia according to the depth your tapping , push it to the max but be carefull you tolerance according to the class of thread called for on the drawing
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
Hi Guys, Thanks for all the suggestions. I am a bit pressed for time at the moment so I will have to give some better feed back at a later stage. In the mean time, however, I found out that our operators have always used the following cycle for tapping. G84 (Tapping cycle) with a delay/pause comand at the bottom of the hole before the retract P500 I would imagine that this would be ok under normal circumstances, however, we are attempting to tap without using a tapping chuck. ie. I want to do rigid tapping using the M29 code. Could our taps have been breaking because we have not been using the rigid tapping code? |
| on a decent machine g84 should work ok , my preference would be to use g95 (inches/rev) and set the feed to 5 decimal points
#10
Feed is dictated by the thread lead. You cannot feed at anything other than the lead value. Are you thinking rpm? In my opinion, if you were to use M29 and a slightly larger drill for your blind holes, your problem would go away. |
#11
| it is obvius that feeds and RPM are rigidly connected when speaking of taps. when i made 3/4 BSP rigid tapping i had to go down to 40 RPM. I didn't break the tap but got Z AXIS SERVO ALARM (daewoo H50 horizontal machine BT50 toolholder). I built tap holder that can compensate axial movements and now i am working in 230 RPM. |
#12
| We tap blind holes on a regular basis. We use the G94 & M29 (FPR & Rigid Tap Mode) and thread form taps. Form taps don’t create any chips so you can run the tap very close to the bottom of the hole. Formed threads are also stronger than cut threads. |
| Left hand taps | cdlenterprises | General Metalwork Discussion | 3 | 04-02-2008 06:28 PM |
| lots of taps | jacek | General Metalwork Discussion | 11 | 04-01-2008 06:07 PM |
| Keep Breaking Taps | Crashmaster | General Metalwork Discussion | 7 | 10-30-2007 02:16 PM |
| Advise on what taps to use for nylon | msomerville | General Material Machining Solutions | 5 | 01-16-2007 02:45 PM |
| Modified ACME TAPS | widgitmaster | General Metalwork Discussion | 2 | 12-13-2005 07:11 PM |
