Old 05-18-2008, 09:37 PM
panaceabea is on a distinguished road
threadmillng questions
The bulk of my work is in aluminum but Mon I have to mill 1.5 x16 tpi in 4130 anealed plate 1" thick. I am using a micro-100 carbide thread mill .
Would like advise on spindle speed and feed rate . Thanks
Old 05-19-2008, 12:21 AM
Gold Member
Caprirs is on a distinguished road
What is the diameter of the thread mill? That should determine a base point for speed/feed.
I just finished thread milling almost 300 holes in 304 SS, although they were a lot smaller at M8 x 1.25 x 14mm deep. I centerdrilled with a .375 spot drill to make a chamfer, then drilled, then flat bottomed the hole with an endmill. The threadmill (.235" dia) ran at 1100rpm and fed at 2ipm. Started over the center of the hole, plunged to the bottom, moved sideways to the wall, then G3 helix up two passes, back to center, retract. Thread mill looks barely used.
Old 05-19-2008, 08:28 AM
1/2" diam
Old 05-19-2008, 09:46 AM
I just found the calculator on the micro 100 site, using it I come up with spindle speed of 1910 rpm and feed of 12.73 IPM .
Old 05-19-2008, 10:41 AM
*Registered*
Mike Stevenson is on a distinguished road
panaceabea,
Those feeds and speeds sound okay to me.
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 03:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 12:40 PM
Ok, So X3 it is - now for the questions. turbostang Benchtop Machines 25 05-30-2008 01:58 PM
Ver. 22: 2 questions spock BobCad-Cam 8 05-07-2007 08:17 AM
new here few questions joey1117 CNCzone Club House 0 01-20-2007 03:32 PM
