Old 05-16-2008, 04:10 PM
twocik is on a distinguished road
4 x 6 Band saw oil ???
I just bought a 4 x 6 harbor freight Band saw and decided to clean the machine before use. Another guy recommended to clean out the gear box. So I did, but now I need to know what kind of oil to use in the gear box ?
I have the Mobil Vactra No. 2 - 4-way oil lubricant, but wasn't sure this was ok to use ?
Old 05-16-2008, 08:03 PM
cam1 is on a distinguished road
If the gearbox uses a worm gear, I'd go with 90W Gear oil. The way lube would probably also work fine, as it's a formulation of a HP gear oil with an additive that makes it sticky. The downside is that more heat will be generated. At the end of the day, you could probably get away with banana peels for lubrication......
PS
I think the advice was well intentioned,
but misguided.Would you change the oil
in the differential of a brand new car?
(if ever).
regards
Can't Fix Stupid
Old 05-16-2008, 08:10 PM
Where can I buy something like this locally ?
Walmart ?
Old 05-16-2008, 08:20 PM
Hi: any automotive supply shop. You can ask for 80W90 gear oil. The way lube will also work fine.
regards
Can't Fix Stupid
Micro Band Saw tikka308 General Metal Working Machines 7 07-25-2007 12:30 AM
band saw blades star1280 General Metalwork Discussion 8 06-27-2007 05:51 PM
Band Saw Barry_ward General Metal Working Machines 3 08-12-2006 09:04 PM
Band Saw Hellbringer General Metal Working Machines 7 01-07-2006 11:42 PM
Band saw cnc wizard WoodWorking 0 04-01-2005 08:37 AM
