Old 05-14-2008, 07:52 AM
ecotectoo is on a distinguished road
Small CNC surface ginder?
I'm looking for a small CNC surface grinder for making reeds. The largest blank I expect to cut is 2"x6" and have little shop space. The smallest one I can find is the Syil U2.
Are there others out there? I've searched around a bit but can't seem to come up with anyone who'd convert an automatic SG to CNC.
And what about software to run a CNC SG? Suggestions? I expect to start from a 2D CAD profile so will need suggestions on how to turn that into g-code as well as whatever controller would use that to run the machine.
-- Rich --
Old 05-14-2008, 08:09 PM
307startup is on a distinguished road
http://www.grizzly.com/products/6-x-...-w-Stand/G5963
I would personally buy this unit, add stepper motors from HomeShopCnc
http://www.homeshopcnc.com/page5.html
run them with the new Gecko 540 (4axis controller) being developed,
http://www.geckodrive.com/
and use Mach 3 software to control it
http://www.machsupport.com/
The actual conversion and wiring would be a matter of asking and viewing ongoing threads of others here on CNCZone.
But that's just me...
Need help with surface finishing GatorMAV Mastercam 9 01-14-2008 05:18 PM
MDT 6 Surface Cut djzepp Autodesk Software (Autocad, Inventor etc) 0 04-10-2007 10:56 PM
Surface Milling camtd EdgeCam 6 10-20-2006 12:08 AM
Small, quick, surface grinding job... InspirationTool Employment Opportunity 3 03-15-2006 11:42 AM
3D surface sub-routine lazza G-Code Programing 2 08-30-2005 08:58 AM
