Results 1 to 5 of 5
Thread: cnc cut 1 inch alum?
    Mar 2008
    newbee.
    Is it posible to cnc router 1 inch alum. with several passes?
    A shape that is 99x19 inches horse shoe.
    Jan 2005
    Yes. I assume by the size that you have a large machine. You need to tell us what you are using to route this and spindle size plus max speed of spindle. it would also help to know what type of aluminum you are thinking of using to make the part.
    Mar 2008
    Machine is EZ-router/plasma 5x10 with 5hp spindle of 20,000 rpm and the alum is 6061.
    Aug 2007
    Good morning Todd,
    We have a 4 x 8 router, porter cable 3 1/4 variable spd (10,000-25,000 rpm). I'm in the process of cutting some .75 6061 T-6. I've been running around 5-6 ipm, air coolant sems to work fine for the first .50 then I have to switch to liquid coolant. I've been doing .12 deep passes, but I think .25 would be no prob. This machine is only a few weeks old, so we're still in the learning curve. For got to mention, we're using a .25 3flute end mill. There is a 2 flute in the pic, but I'm using that to keep going until fedex shows up with my bits.
    Mike
    Attached Thumbnails Attached Thumbnails cnc cut 1 inch alum?-cnc_router_build_025.jpg
    Aug 2007
    One more thing, check out McMaster-Carr for cutting bits. Been a good source for us, they carry just about everything.
    Mike
    1. Milling Alum.
      By Smackre in forum General Metalwork Discussion
      Last Post: 11-22-2006, 08:10 PM
    2. RFQ - Alum Anchor Block - A
      By jlm in forum Employment Opportunity
      Last Post: 08-29-2005, 11:12 AM
    3. Alum Honeycomb core
      By CNCadmin in forum CNCzone Club House
      Last Post: 06-12-2005, 12:26 AM
    4. Alum Angle
      By Ursine in forum DIY CNC Router Table Machines
      Last Post: 05-13-2005, 07:49 AM
    5. turns per inch vs threads per inch
      By pminmo in forum DIY CNC Router Table Machines
      Last Post: 08-18-2004, 10:27 AM
