Old 04-28-2008, 12:14 AM
pmurdock is on a distinguished road
bq drill rod, threading (tapered, square thread)
I'm looking at making some tooling that will attach to drill rod. The threading is 3 threads per inch (square thread). What is the best way to do this? I've looked at the catalogs for vardex and kennametal and I don't see any inserts for square threads for use on our haas sl-30 cnc.
Since it's a square thread with a very large thread per inch, I wonder if I can't just use a boring bar with a helix cut pattern to create this thread.
I believe it's a tapered thread as well (at 2 deg)
any suggestions?
cheers,
Paul
Old 04-28-2008, 07:12 AM
zdude is on a distinguished road
Threading Tool
If you you only have to make 1 piece, you may get by grinding your own cutting tool out of HSS.
Old 04-28-2008, 07:34 AM
Red Frog is on a distinguished road
Thread solutions
Iscar makes threading tools for your application. In fact they have just engineered a rock solid laydown insert that doesn't move while threading. They are made for both I.D. and O.D. threading. I don't think you should try a simple threading cycle. Start with large cuts and decrease as you get to finish size. My finish passes are no more than .005 d.o.c.
Old 04-28-2008, 08:26 AM
thesaurian is on a distinguished road
I believe that you should be able to start your threading cycle at two separate points tho create a wider thread form. Imagine if the threading groove cut is .167 wide, then subtract the width of your tool from that dimension and use two separate threading cycles starting at a point ".167-x" away from the original start point along the same plane as your first cycle. It's been a while since I had to cut multiple start threads, but this should be no different than that, other than you are not starting at a point 1/2 th pitch or 1/3 the pitch away.
Let me know how you make out. Are you satisfied with your Haas?
Old 04-28-2008, 01:21 PM
yasco is on a distinguished road
Hi Paul:
The BQ rod thread is indeed tapered, but not exactly 2 degrees. The inserts are special, not just a square thread, and you must have them made to order.
Is the thread you need male or female? Do you need to make just one piece or how many? If you e-mail me a print, I might be able to help.
Best regards,
Yasco
yasco@comcast.net
Old 04-28-2008, 05:55 PM
I was thinking along these lines.. thanks for the tips..
The Haas has been a great machine. Had to work out some kinks with the tool pre-setter but it holds it's tolerances quite well and is very easy to use.
cheers,
Paul
Old 04-28-2008, 05:57 PM
Do you by chance know where they show that on the web site. I looked through their catalog and didn't see anything. I image it's some type of buttress thread.
cheers,
Paul
Old 04-29-2008, 04:00 AM
Correction
I am truly sorry. I gave you the wrong information. The manufacturer is Sandvik. CoroThread 266 is the model.
Old 04-30-2008, 12:33 AM
CoroThread 266.. interesting I was looking at the spec sheets and didn't see any standard threads.. I did see however the "tailor made" variety where you can specify the threaded insert.. is that what you were referring to? Meaning I have to specify to them the insert dimensions?
cheers,
Paul
What type of drill rod for easy threading using die? ngr1 General Metalwork Discussion 10 12-14-2010 04:03 AM
Problem- TL-2 Tapered Thread Problem dhelms Haas Lathes 5 04-21-2008 01:27 AM
Proper diameter drill rod or bar stock for threading? quick toy Mini Lathe 6 12-02-2007 06:34 PM
Square Column Mill/Drill Conversion Jay Kyle Vertical Mill, Lathe Project Log 14 08-23-2005 01:42 PM
threading thread... charleyy DIY-CNC Router Table Machines 11 08-29-2004 11:16 AM
