Old 04-27-2008, 01:26 PM
manoharan is on a distinguished road
Need help what type flappy must use in NC feeder
Hi friends,
Machine: CNC Turning centre, 11T Fanuc.
My problem: Load program to Crt screen. I used ordinary flappy, program typed from personel computer. I used Facit NC feeder N1060 for output program from flappy. But this ordinary flappy not accept to read program to output.
What type flappy may I use? Please help me someone.
Thanks & Regard,
manoharan.
Old 04-28-2008, 09:32 PM
Mazaholic's Avatar
Mazaholic is on a distinguished road
http://www.members.tripod.com/facit_...ets/n1060.html
Old 04-29-2008, 03:42 AM
nwrepair1 is on a distinguished road
Did the previous answer help? It uses a standard floppy disk. If you are using a DOS system, you need to keep file names no larger than 11 characters including the dot before the file extension. Example: abcdefg.txt
Old 04-29-2008, 06:05 AM
Mazaholic's Avatar
Thanks & Regard,
manoharan.
The Facit N1060 NC Feeder Disk Drive automatically recognizes inserted MF2-DD or MF2-HD disks
Maybe i misunderstood the question?
Old 04-30-2008, 09:24 AM
I was very happy to receive your helpful letter Mr.Mazaholic. I will try.
Thanking you very much,
manoharan.
Old 04-30-2008, 09:36 AM
Thanking you very much Mr.nwrepair1. My file name I kept 01234 as only 5 character. Mazaholic gave right solution.
Thanks and regard,
manoharan.
Servo 300 Bar Feeder wudbutcher Haas Lathes 18 08-24-2010 10:17 AM
MTA 541 Bar feeder DocHod General CNC (Mill and Lathe) Control Software (NC) 0 10-02-2007 10:03 PM
auto feeder Syphonics Mechanical Calculations/Engineering Design 9 12-20-2006 09:14 AM
Simple Bar Feeder Jarwalcot General Metal Working Machines 4 02-24-2006 01:10 PM
