I have a bridgeport series II heidenhain cnc I'm making parts with just clearance holes for bolts everything has been running great I was just wondering how much harder I can push the bit I'm new to cnc but experienced manual machinist so i'm used to going by feel and how tired my arm is, here are my conditions. 1. .400 drill (inches) 2. flood coolant 3. 1018 cold rolled steel .750 inch thick 4. peck drilling .060 peck feed rate 15 ipm I think this maybe a little conservative but the chip looks good and it sounds good I guess there probably formulas in the machinist handbook but its Sunday and feeling pretty lazy. Plus just asking people with experience has proven more worthwhile ( most of the time) |
| .06 DOC is awfully shallow for a drill of that size. Pecking takes time. Can you increase the peck depth, and still have the chips clearing? Based on your drill size and what I would run the drill in IPR, I would say you are running a carbide drill. Otherwise I think you are already running a pretty hefty feedrate. On a lathe, I would be running a carbide drill of that size to that depth in one shot. I've never run a mill. I am basing my comments on 23 years of programming/setting-up/running lathes. I would like to know what values you finally wind up with. Just for the sake of gaining a little more knowledge. Thanks. |
| g-codeguy No actually I'm just running a cobalt stub length drill but my feedrate calculation maybe wrong I have an old heidenhain and to be honest I'm not sure how the feed rate is measured ( sorry cnc newbie ) my number in the last post must be wrong because it almost seems painfully slow so I'll figure out the true feedrate I'm running Yes I can bump up the pecking depth I'll try half way first (.375) and make sure the chips are clearing. I'll keep you posted on what I figure out |
When i peck drill i usually only peck the diameter of the drill and i never have problems. |
| The depth of the peck depends on what type of peck cycle your using. If you are cutting and retracting out of the hole,you need to take deeper cuts. If you are just breaking chips..cutting 60 retracting 15 and cutting 60, you can ramp up the spindle speed quit a bit. and possibly the feed. I'm assuming your drilling thru some kind of flange,if so,and it's not very thick,you can use the chip breaking cycle and get pretty extreme with it. |
Figured I'd cover a couple bases this time. |
| best thing to do is look at the drill manufacturer's recommended sfm for the specified materials your running , typically if you go beyond that you face premature wear , chipping or fatigue which will result in premature tool breakage
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| I took Rmarch advice of pecking the Diameter of the drill That worked great I'll use it for a rule of thumb. G-code guy I'm green at gcode I'm just starting to figure out the feedrates right now am going by trial and error but want to know the correct way so I'm running 1000 rpm .397 drill then in the canned cycle it ask me for the feedrate so I typed in 150 to see what happens and it was moving in my mind at a good rate it was making a good chip not spinning in the holder and the surface walls don't look chewed up and scored. So my question is what is the 150 really telling me as far as feedrate? I originally said 15 because when milling I was told when putting in a feedrate of 200 in a linear interpolation that equates to 20ipm I realize that there is a difference between drilling and milling but the light switch in my head hasn't turned on for the feedrates. |
#11
| If you are running at 1000 rpm and 15 ipm, you have a feed rate of .015" fpr, which is adequate for a drill of that size. You COULD push it a little harder, if you are in a great big hurry, but tool life will probably suffer. |
| casting a push mower deck | fastolds | Employment Opportunity | 2 | 09-11-2008 08:48 AM |
| Where to find push-button oil hole valves? | Claven2 | Mini Lathe | 6 | 04-17-2008 09:01 AM |
| push rod | stem fan1 | Steam Engines | 4 | 06-26-2007 06:01 PM |
| Need Simple Push Button Controller | edo | Stepper Motors and Drives | 28 | 02-02-2007 04:32 PM |
| How fast should it go, how far to push it. | jaywhy71 | WoodWorking | 9 | 11-11-2006 07:25 AM |
