Old 04-24-2008, 06:51 PM
stickben is on a distinguished road
CNC retrofit, coupling motors
Hello,
Just wondering, I want to fit my mill with steppers and a control box to create a CNC machine. What is the best way to couple the shaft of the motor to the lead screw? Most of the couplers I have seen usually have the same input and output shaft diameter. The mill has a 17mm shaft, do NEMA23 motors have a standard shaft size? I was thinking about getting the 305oz kit from hobbycnc. Do you think the 305oz motors are strong enough for a medium sized table top mill? The mill has removable hand wheels that have some sort 3 prong interlocking teeth that mesh together in order to turn the screws. Does this sort of interlock have a name? I was thinking that I might be able to make somthing to go on the end of the motors that meshes with what is already on the lead screws.
Any Ideas?
Thanks!
Ben
Old 04-25-2008, 08:39 PM
mackeym is on a distinguished road
305 oz-in is adequate. You could turn the ID on one end of the coupler to a different diameter as long as it's not big diameter change. Could you order a few of the hand wheels, and take the 3 prong interlocking teeth off the hand wheel and put it on your motor?
Need to get the right Lovejoy coupling. Can anyone help? alexccmeister Benchtop Machines 26 06-08-2007 08:28 PM
Help On Choosing coupling Brenck Mechanical Calculations/Engineering Design 13 05-17-2007 03:24 PM
I Need Some Coupling Suggestions. ljoe1969 DIY-CNC Router Table Machines 8 05-07-2007 07:20 PM
Coupling Help Gorillakilla General Metalwork Discussion 6 01-24-2006 10:04 AM
Bridgeport Retrofit Using Brushless AC Servo Motors? Eric Servo Motors and Drives 6 12-05-2004 09:58 AM
