Old 04-24-2008, 10:03 AM
orizaba is on a distinguished road
Trouble getting home
I have a 1998 Anilam 3300mk on an HH Roberts bed mill. In the morning when I home it, sometimes the x axis will rapid to the -x hard stop. If I anticipate this and E-stop it, reboot and rehome it (2 or 3 times) it will eventually home normally and run fine all day.
Any ideas about this?
Old 04-24-2008, 01:16 PM
HuFlungDung's Avatar
Moderator
Runaway is indicative of encoder (or cable) problems. Could be either the encoder or perhaps a power supply getting weak, although the latter would probably affect all axis about the same way.
Throughly check the cable connections first.
Old 04-24-2008, 05:58 PM
Thank you, once again.
Matt
The trouble with SE split63 SolidEdge 5 10-23-2008 11:59 PM
Need Help!- Home again Home again Jiggety Jig. Well Not Just Yet! Mr.Chips DIY-CNC Router Table Machines 10 03-18-2008 08:58 PM
THC trouble? Red Earth DynaCNC 5 07-01-2007 09:04 AM
More PIC trouble robe_uk PicStep Controllers 5 10-10-2006 03:13 PM
Arc trouble Graeme TurboCNC 9 06-24-2005 03:31 AM
