Old 04-16-2008, 10:47 PM
cnczoner is on a distinguished road
6-flute endmill for finishing aluminum?
Hi all,
My mill does 1500rpm max, and I'm roughing, then using a separate endmill for finishing 6061-T6. The usual recommendation is to use 2-flute EM's for aluminum (general milling) for increased chip clearance between the flutes, but if I'm just finishing (profile) taking about .010" to .030" off, couldn't I use a 1/2" 6-flute endmill, as the chips would be much smaller (both because of the light pass, and because there's more flutes)? My thought smaller chips should get me a finer finish, and I could perhaps increase the feed rate a bit too. The mill has 1.5 hp which is more than I need for this.
I'm thinking I'd pick up a Hanita 6-flute 1/2" endmill from JL for ~$30.
Cheers,
-Neil.
Old 04-16-2008, 10:57 PM
crazythunder is on a distinguished road
Thumbs up
Sure I would keep my chip load per tooth between .003 to .005 and run the rpm at 1500. For that little of money for the endmill do not see any problems make sure you are getting the chips out of the way with either air or coolant.
Old 04-16-2008, 10:59 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
6flt should get a good finish with light cuts , i used to do alum. castings that had to be perfect , we cut them with a 3/4 8flt and when we tried to farm the job out everyone said we were grinding the parts to accomplish that kind of finish , we never did tell anyone how we did it
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 04-16-2008, 11:20 PM
Cool. I think it's a fairly low cost experiment anyway.
Thanks.
Tapping aluminum. Spiral flute or not ? Argofanatic General Metalwork Discussion 20 02-17-2007 08:21 AM
Sqealing .75" 6 flute endmill jderou General Metal Working Machines 3 03-13-2006 07:48 AM
1/32 Endmill cutting aluminum? DennisCNC General Metalwork Discussion 5 12-26-2005 11:22 PM
3 Flute High Helix Endmill Problem Joe_CNC General Metalwork Discussion 7 07-19-2005 07:07 PM
Machine Aluminum... Spindle speed and flute count ngr1 General Metalwork Discussion 6 01-03-2005 11:35 PM
