Old 04-16-2008, 02:35 PM
Ithink is on a distinguished road
Question optically 'ribbed' surface
Has anyone experience how to polish 'ribbed' surface on moulds.
Regardless the precision of our machine, and well adjusted spindel all flat surfaces are still optically "ribbed".
Do you beleive that there are abrasive tools non-dangerous for spindel?
Old 04-16-2008, 06:19 PM
Torsten's Avatar
Torsten is on a distinguished road
Yup, there is a way.
You are probably not gone like it, but polishing molds is still done mostly by handwork.
Old 04-22-2008, 02:59 PM
bugzpulverizer's Avatar
bugzpulverizer is on a distinguished road
This is just a shot in the dark, but I used to have what looked like perpendicular to the cut rib problems with 3-D contour milling. If that made sense. What I found out was that basically it was caused by the program spitting out splines instead of arcs. Try increasing filter on your cad software. It might help.
Optically Clear Adhesive ejlouis Laser Engraving & Cutting Machines 0 07-24-2007 04:05 PM
Surface finish chakaloso General Metal Working Machines 0 06-12-2007 08:54 PM
MDT 6 Surface Cut djzepp Autodesk Software (Autocad, Inventor etc) 0 04-10-2007 10:56 PM
32 surface finish mroy0404 General Metalwork Discussion 4 05-28-2006 09:02 PM
could you check my surface. corrie Rhino 3D 12 04-08-2006 08:35 PM
