Old 04-12-2008, 01:41 PM
jrobson is on a distinguished road
Machining time
Just curious but what would you say is a resonable time to machine this part in?
Old 04-12-2008, 01:42 PM
Forgot to mention, just the inner profile, drilling the 4 holes, also tapping them.
Old 04-13-2008, 01:22 PM
RMM97502 is on a distinguished road
Material? Tolerances?
Old 04-13-2008, 02:01 PM
Suppose that would help Aluminum 6061, Tolerance is 0.025mm on the 5mm high walls, other than that not very important, BUT I do get a nice mirror finish on the walls so yeah you can push it but of course the finish must not suffer too much.
I am cutting it with 2 Flute Alu-Cut cutters @ 10000rpm(max of the machine) and am running 1:30 flat per part cycle time, would like to know how close I am to optimum with the 2 flute cutters, when I wear them out I'll move over to 3 flutes and should cut 20 seconds or so, but my supplier didn't have any.
Roughing with 8mm, finishing with 4mm.
Regards,
Jonathan.
Old 04-13-2008, 02:04 PM
Sample attached...
Old 04-13-2008, 02:08 PM
1:30 sounds like you're pretty close to optimum. I took your .xt file and put some toolpath to it in MasterCam. I got a cycle time of 1:50 without really looking too deeply. With some tweeking it could get somewhat better but sounds like you're on target.
Old 04-13-2008, 02:28 PM
Cool thanks for taking the time, very good to know.
Regards,
Jonathan.
Weee! first time machining Stainless Steel ImanCarrot General Metalwork Discussion 7 02-08-2008 01:25 PM
Estimating machining time wildcat Mach Software (ArtSoft software) 4 11-20-2006 07:35 PM
machining Aluminum for the first time. carguy327 General Metalwork Discussion 10 10-26-2006 07:27 PM
Machining Time mmike76 General CAM Discussion 9 04-09-2006 08:07 AM
Getting the machining time HuFlungDung OneCNC 8 05-15-2003 01:06 PM
