Hi all, Using 1/8" Enco 2-flute, 3/8" LOC, 3/8" shank, uncoated HSS endmills on 6061-T6. Slotting at 1500rpm, 0.05" doc, 5ipm, the endmills are breaking. I'm also lubing with ATF. So I slowed down the feedrate to 1.5 ipm and that worked, but a simple part took 1.5 hrs! ![]() I hear of people machining much faster than this, so is this related to my 1500rpm spindle? Should I use less DOC and faster feed? Is there perhaps a different type of endmill I should be using? Most other endmills talk about harder cutting edges, but I'm not sure if Carbide or other materials are actually stronger so that I can cut faster...??? ![]() Cheers, -Neil. |
| So a higher spindle speed will allow me to use a higher feedrate without breaking the bit? I could easily make a mount for a dremel rotary tool on my spindle head, but I may run out of hp... I need to lookup how my hp a dremel tool has. Does your calculator give you hp required? If so, how much hp is required to run 1 1/8" endmill at say 10,000 rpm and 20ipm, with a 0.05" doc? Or perhaps I should ask how fast can I feed with a dremel at 10,000 rpm and 0.05" doc? Thanks, -Neil. |
| What kind of machine do you have? You may want to consider a spindle speed increaser. I don't think dremels have a very stable spindle..... You could also try to find a high speed spindle. Like this one http://www.homeshopcnc.com/page7.html zac |
| This is my mill. The motor does 1800rpm (1.5hp), but after gearing it will do 1500rpm max. Last year I was planning to swap the motor to a 3600 rpm version, but the motor is some not-so-common frame size, and getting a higher-rpm version would only be from a few sources with a high price tag (IIRC ~$400-$600). I could make an adapter plate and adapter bushing to use a more common motor (like Nema 56), but I also want to keep it 110V (as I'm running this in a detached garage), and I wanted to get a motor which would let me use a VFD, but that would probably mean getting a 110V-in, 220V-out VFD, then using a 220V motor. A simple motor swap became a bit involved, so I put it on hold for now. If I found the correct-sized motor right now, which allowed me to use it on 110V and 220V, I'd jump on it, but for now I've got to work with what I have. BTW, I'm not doing anything production, but I still think 1.5ipm is ridiculously slow. ![]() Cheers, -Neil. |
| Maybe you could try an end mill with a shorter length of cut (stub end mill). Also consider a four-flute. With only .050 depth of cut, you might get away with the chips not packing in the flutes - air blast or coolant will help.
__________________ Software For Metalworking http://closetolerancesoftware.com |
| Currently using a 3/8" LOC, which is quite short already, and I'm cutting to a total depth of just over 0.25". Also, squirting on ATF and vacuuming periodically. Interesting thought on the 4-flute -- I have a set of 4-flutes here, but need to check if it goes down to 1/8". But still wondering if different types of endmills might allow me to get higher feedrates? Cheers, -Neil. |
That's the benefit of a stub end mill. I didn't realize that you were going .250 total depth. The stubbie would work with one or two .050 passes, but not five.
| Maybe you could get all but the last pass with the stronger stub end mill - LOC on these is 3/16 http://www.richardsmicrotool.com/page29.htm
#10
| Hi cnczoner Is this cnc or are you turning the handles, by the link it is a manual machine ATF is not that good for cutting fluid WD 40 would be much better in your case & cheaper how are you holding the endmill if you are using a drill chuck that is not very good as it does not hold the end mill rigid enough you need a soild or collet holder to hold the cutter.
__________________ Mactec54 |
#11
| The mill is CNC'ed. I recently switched from WD-40 to ATF after some recommendations. So far I think I get a cleaner cut with ATF, but I haven't run comparisons to see which way is making the endmills hotter. I really need to get a cooling system, but I'm still evaluating compressor-less systems (since I'm doing this in a garage in an apartment complex and need to be as quiet as possible), plus I need to figure out some type of enclosure. The endmill is held in R8 collets now. Cheers, -Neil. |
#12
| I found this interesting writeup, and it seems that I should get more feed-rate from solid-carbide, smaller LOC, and a few more flutes. I have an Enco order going out shortly, so I'll add in some endmills that fit these parameters. Cheers, -Neil. |
| Breaking chips | yoopertool | CNC Swiss Screw Machines | 15 | 10-18-2007 04:47 AM |
| I keep breaking bits! | mccombbj | Benchtop Machines | 35 | 06-30-2007 09:45 AM |
| How to clean mini mill coolant cheaply and easily? | 1ctoolfool | Haas Mills | 14 | 01-15-2007 07:10 PM |
| New TechProbe Digitizer Scans 2-and-3 Dimensional Objects Quickly and Easily | carolpratt | Product Announcements & Manufacturer News | 0 | 12-05-2006 01:57 PM |
| Easily trace an image into your CAD | Graphcon | Product Announcements & Manufacturer News | 0 | 11-14-2003 06:30 AM |
