| need a bandsaw Guys, Im looking or a band saw that like this one at Harbor Fright. My problem is the harbor fright band saw is a 62 inch blade and I can only find bi metal blades that size. I have also been to Sears and Home Depot with no luck. Any suggestions Tek |
| may be ? http://www.highland-hardware.com/ind...OD&ProdID=1295 costum blades for 30.00 and http://www.toolcenter.com/Lenox/62blades.htm never used them just came up on my searchs. so check them out befor sending your money |
| www.suffolkmachinery.com is another option. Just give them a call and tell them what saw you have and what you're trying to cut and they'll do the rest. In my experience they tend to insist on being helpful. Out of curiosity, what are you trying to cut? A jigsaw would be a better option (and less expensive in the blade department). I would not anticipate doing a lot of resawing with this three-wheeler. |
| Little Machine Shop has some good blades. |
I plan to cut up to 3/8" aluminum |
| If the cuts are straight, just use a table saw with carbide blade. I do it all the time and have cut up to 3/4 inch plate with no problems.
| Most of the cuts will be straight but I need to do round corners |
| Vertical/Horizontal Bandsaw purchase | ChrisJ | General Metalwork Discussion | 3 | 07-21-2007 09:30 AM |
| Bandsaw Blade recommendation needed | Swami | General Metalwork Discussion | 7 | 03-15-2005 12:08 PM |
| need help; bandsaw blade welder | SteveD | Machine Problems, Solutions , Wireless DNC, serial port | 2 | 05-20-2004 02:55 PM |
| Bandsaw accuracy? | gtslabs | General Metalwork Discussion | 3 | 12-29-2003 10:26 PM |
| Can you cut Al. with a wood bandsaw | CactusChip | General Metalwork Discussion | 5 | 11-20-2003 04:45 PM |
