Old 03-20-2008, 09:17 PM
ak_crabber is on a distinguished road
deep hole tapping problem
well i started this new job the other day and they give me this part. its a simple turnbuckle.
its either 306 stainless or 318 stainless....not extremely hard metal. But i have to tap 2 holes on each end of the short rod....and the holes are to be tapped 3 1/2 inches deep.
the machine is a smaller Mazak mill and I'm a gcode programmer so naturally i had an issue from the get go. i guess EIA is ok. i found out there was no peck tapping canned cycle.
its to be tapped 1/2 inch -13. predrilling 27/64 was putting too much pressure on the tap so i went to 7/16. had it running fine with a special made tap (left hand tap that was 7 1/2 inches long)
anyway, i ended up breaking taps after about 3-4 parts
can you recommend me a tap that i can straight g84 it to the bottom without having to manually write out a peck tap cycle
basically my prog went like this
n3g00g90g54x0y0;
t18m06;
s70m4;
g43h18z1.m08;
g84g95g98z-.5r.1f.0769;
(repeated this line all the way to -3.5
should i try a hypro tap????
give me a recommendation of something that will pull the chips out and not break
Old 03-20-2008, 11:14 PM
little bubba is on a distinguished road
I really want to be a jackass, but EIA/ISO is G-CODE. You can't count on every machine having every little canned cycle your used to. They all differ, I wish they would standardize, but its not going to happen. Its all just syntax.
Your using multiple cycles to get to depth, thats fine, that is exactly what I would do.
To cure your problem, form tap it. No chips, no problem. I know its "stainless" but your in the 300 series, its about as hard as snot until you start moving it around. Run that sucker in there, one shot and done. You're probably in the custom tap size and length, plus the left hand, but the damn things last.
Old 03-20-2008, 11:40 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Try to add a Q value to G84 to get a peck tapping cycle.
Stefan Vendin
Old 03-21-2008, 03:58 AM
davereagan is on a distinguished road
I tapped 160 1/2"-13 blind holes 1" deep in 316 stainless using a Vega Vanadium, Tin coated hi performance tap. I ran it around 70 rpm and pecked every .2" I would not dream of tapping deep without pecking, even if it was just cold rolled steel. I used Tap Magic Heavy but I think Tap Magic w/EP extra would have been ok. Flood coolant is out on stainless except 303.
Old 03-21-2008, 06:47 AM
understood......
if it was that easy i wouldnt have made the post in the first place....
Old 03-21-2008, 06:48 AM
tried that but no....mazaks get mad unless you use mazatrol
Old 03-21-2008, 06:38 PM
fuzzyracing1967 is on a distinguished road
I have what may seem a dumb question,but when are your taps breaking? The reason I ask is I had a simular problem once,( deep hole,stainless ).What was happining for me was the tap was breaking on the way out,the hole would close back up just enough that the tap would have to back tap on the way out.What ended up working was using trimtap heavy,(the stuff is like honey)to tap the parts,was a pain but it worked.
Old 02-03-2009, 09:47 PM
HamerHead is on a distinguished road
Use a roll tap.
I taped titanium 2" deep, with 1/4-20 roll tap on a Hardinge CNC lathe!
Used this white grease like compound for lubricant.
Forgot the name of it, it's been years.
Old 02-04-2009, 11:22 AM
pdoherty is on a distinguished road
If it was many years ago, it was probably white lead. Works wonders on stainless tapping jobs, but obviously not a good plan from a heath & regulatory standpoint.
We use a product called 'white lead replacement' that is about 20% as good as the real thing.
Old 02-05-2009, 05:44 PM
coolantman's Avatar
coolantman is on a distinguished road
EnviroCut 2524 works great on stainless. Use straight!!
Deep hole drilling kalmah General Metalwork Discussion 8 09-09-2007 10:09 AM
RFQ: Deep hole drilling in several materials m-134b Employment Opportunity 3 08-23-2007 05:55 PM
small, deep aluminum hole Hoeken General Metalwork Discussion 5 04-27-2007 05:52 PM
Can an X1 bore a deep 70mm dia hole in Al? digits Benchtop Machines 59 03-04-2007 09:24 AM
Deep hole drilling on OKK eddie G-Code Programing 1 09-21-2005 06:55 PM
