Old 03-20-2008, 04:55 PM
rhino's Avatar
rhino is on a distinguished road
Rotary Broaching
Hey Fellow Cncoligists,
Been searching for a while for a broach i used in a cnc lathe at a place where i started my apprenticeship. Voila! i found it this morning! the process is called rotary broaching "duh!." I saw a website called http://www.slatertools.com or http://www.rotarybroaching.com (same website). anyway there is a video link up the top of the page on how it works.
Has anyone had any experience with this stuff? Please post your thoughts.
Rhino
On the other hand, You have different fingers.
Old 03-20-2008, 07:04 PM
laka is on a distinguished road
We've used them before in brass, alum, and some 4140.
If you set them up properly, they work very well. Just make sure to keep her greased.
Old 03-20-2008, 11:19 PM
little bubba is on a distinguished road
Once you grasp how they work it makes perfect sense. A very powerful tool to have in your backpocket.
They take a lot of force, my experience is a 12 point 3/8 hex on a 17-4 bolt. Hundreds of them. Its a fantastic process, but your equipment needs to be up to it. I blew out the power feed on two lathes and popped a servo on a less than powerful CNC. Ended up with a cheater bar on the turret. I was very sore for a while.
Old 03-21-2008, 07:26 AM
djr76's Avatar
djr76 is on a distinguished road
I just did a job in plastics making pulleys with 11/16 hex, the tool works great. Its a little tricky in plastics not getting blowout on the backside of a through hole but all in all a very cool tool.
Old 03-21-2008, 03:35 PM
peter@slater is on a distinguished road
Rotary or Wobble Broaching
Rhino, Did you get a chance to look at the Customer Showcase at the bottom of the rotarybroaching.com page? There's a bunch of comments about how it's been for those guys who are using the tooling. Set-up is easier now if you can use Slater's adjustment free tool holders.
Old 03-21-2008, 04:29 PM
MazakMikeO is on a distinguished road
Just be sure to get the bore size right and it's fine. Used to machine a 6mm hex in 316 handles (thousands of them) and it was fine.
Old 03-21-2008, 06:57 PM
fuzzyracing1967 is on a distinguished road
That is damm cool,never scene one of those before! In the video it makes a quick refferance to keyways,but on the site I didn't find any tooling to do keyways,or did I miss it somehow?
Old 03-24-2008, 07:49 AM
Rotary Broaching a Keyway
There are some limitations with forms that can be broached using rotary broaching tools, and keyways are one of them. For whatever reason, single keyways can be almost impossible to rotary broach. The cutting action requires the broach to 'wobble' or rotate the full diameter of the form, and because the keyway is only on one side, the uneven pressure often causes the broaches to break - resulting in poor tool life. Keyway depth must be shallow as well.
However, there is any easy solution! If permissable, just add a few more keyways, and then you will even out the form. A quick fax to your rotary broach manufaturer, with OD and ID dims, will get you an answer if it will work, and how much it will cost.
Old 03-28-2008, 10:12 PM
rhino's Avatar
Thanks for the feedback! A Couple of Qestions Though:
Peter@slater:
I take it you are a rep? am i correct? i have left numerous e-mails with the slater tools "contact us" page to contact "ME" but have had no reply.
Do you have Australian Reps? Let me know or pm me some contact details please.
laka:
Out of curoiosity, what size were you broaching in 4140? when i put this concept to my boss i had a couple of jobs in mind. it will beat the SH*T out of welding cap screw heads into the head of our products!
Old 03-31-2008, 07:42 AM
Sorry about the mess.
I do some technical work for Slater. We were having some 'issues' with the contact us page on our website, but I believe it's fixed now. If you need anything, send me a personal message and I'll take of you.
4140 is great for rotary broaching. It most cases it also has very good tool life, probably up to about 20mm/.75inch. Alot depends on the depth of the hole, pre-drill size and capability of your machine.
  #11   Ban this user!
Old 09-16-2011, 01:15 PM
polygon's Avatar
polygon is on a distinguished road
Rotary Broaching Video Demonstration
Here is a great video demonstrating the rotary broaching process using a Bridgeport:
http://www.polygonsolutions.com
Tags
bridgeport, rotary broaching
Online Rotary Broaching Video peter@slater Product Announcements & Manufacturer News 6 01-04-2012 11:24 PM
mazak integrex broaching precisiontork Mazak, Mitsubishi, Mazatrol 5 10-27-2008 07:57 AM
Premium Rotary Broaching Products from PCM Switzerland SwissType1 Product Announcements & Manufacturer News 0 10-30-2007 03:39 PM
Broaching advice Al_The_Man General Metalwork Discussion 9 12-19-2006 05:03 AM
Automating the Broaching process Donald Mechanical Calculations/Engineering Design 20 10-20-2006 04:09 PM
