Old 03-20-2008, 12:10 PM
apex55 is on a distinguished road
Tool Holders
What's better a BT or CT toolholder and what are the advantages or disadvantages of each? I'm currently looking at VMC's
Old 03-21-2008, 04:55 PM
MazakMikeO is on a distinguished road
Do you mean BT and CAT? The only difference I have noticed is CAT holders only go into the toolchanger one way, BT can go in either way. There may be a difference in prices or in syles of holders you can get, but I'm not sure on that.
Old 03-21-2008, 08:21 PM
TheGreenMachine is on a distinguished road
We have a machine that uses CT40 (CAT40) and a machine that uses BT40, they look very similar, same approximate size and taper. In practice I don't think you will see a performance advantage from one to the other, but I believe the CAT40 is more common probably making them easier to find and cheaper. They are not interchangeable.
Old 03-21-2008, 09:09 PM
Gold Member
Caprirs is on a distinguished road
BT tool holders have metric threads for the retention knobs whereas CAT uses inch threads.
Also, the groove on the flange is located a little lower on BT tools compared to CAT. On a lot of machines, this prevents using BT and CAT in the same magazine/carousel.
GS Tool Holders big_mak CNC Tooling 18 03-31-2011 12:58 PM
GS Tool Holders? leggetmachine General Metalwork Discussion 2 10-31-2006 09:12 PM
tool holders barnesy General Metalwork Discussion 2 07-08-2006 03:54 AM
Tool holders zachf CNC Machining Centers 3 01-27-2005 05:17 PM
Old cnc tool holders glmoore General Metal Working Machines 8 05-31-2003 06:37 PM
