Old 03-17-2008, 10:49 PM
FPV_GTp is on a distinguished road
help?? identify lathes chuck mounting flange
Ok need some help identify this lathes chuck mounting flange ?
I had no success trying to find any information the web
The lathe has a tag on it and reads : " Made in Poland , Metalexport Warszawa ) 1965
I have scanned and added some pictures of the flange.
I need to adapt a 3 and 4 jaw chuck to this lathe.
any help would be appreciated
ID:	55725   Click image for larger version
ID:	55726   Click image for larger version
ID:	55727   Click image for larger version
Old 03-23-2008, 10:08 PM
Lathe Spindle Nose & Backplate Fittings
Hi
After searching the web for the past few days I final found some MAYBE useful information
Found this link http://www.lathes.co.uk/latheparts/page11.html
German Standard Spindle Noses - short taper with Bolt or Stud Fixing Forms A and B Din 55021
Seems my lathe has a Lathe Spindle Nose Fitting German Standard Spindle Noses Short taper with Bolt or Stud Fixing Forms A and B Din 55021.
Will now cross reference to see if mine has any of these measurements
Here are a few other types of Lathe Spindle Nose & Backplate Fittings
http://www.lathes.co.uk/latheparts/page8.html
SPINDLE NOSE FITTINGS
American long Taper with Drive Key and Draw-nut Types L00, L0, L1, L2 and L3
AMERICAN STANDARD SPINDLE NOSES - Direct Mounting
American short Taper with Bolt or Stud Fixing Types A1, A2, B1 and B2
American short Taper with Camlock Fitting Type D1
British and ISO Standard Spindle Noses - Direct Mounting
British & ISO Short Taper with Bolt or Stud Fixing
British & ISO Short Taper with Camlock Fixing
British & ISO short Taper with Bayonet Ring Fixing
BACKPLATE FITTINGS
Cam-lock D1-2", D1-4" etc
American Long Taper L Types L00, L1, L2 and L3
Short Taper A-1, A-2, B-1, B-2, with Bayonet
"A Type" Screw Fitting
Might help someone else if they are trying to determine the style of their lathes backing plate pattern.
If anyone finds an other different styles just post a link for others to use and share information
cheers
Old 03-23-2008, 10:15 PM
#3 Morse taper shank with 3/8-16 threaded hole in rear for securing with drawbar http://www.glennview.com/tools.htm
Old 03-23-2008, 11:00 PM
Specifications For American
Specifications For American Lathe Spindle Noses http://shopswarf.orconhosting.net.nz/chuckmt.html
Lathe Chucks and Adapters
http://www.littlemachineshop.com/pro...s=Lathe+Chucks
CNC COLLET CHUCK Dunham Tool manufactures a high quality 2j CNC collet chuck, http://www.dunhamtool.com/cnc_collet_chuck.html
here even for woodworks TEKNATOOL WOOD LATHE CHUCK JAW SETS
http://www.thewoodworks.com.au/site/...5oSIiiIB04mxng
Old 03-23-2008, 11:22 PM
German Standard DIN 55027 Spindle type " C " is what i have on my lathe
http://www.workholding.com/BISON-SPI...-L-THD-DIN.htm
Old 03-23-2008, 11:28 PM
sometimes using the right words in " serach engine helps "
Chuck Adapter Plate for C6 Lathe
http://www.mini-lathe.com/C6_lathe/B.../backplate.htm
Old 03-23-2008, 11:33 PM
DIN 55028-c / ISO 702/111 / ASA B5.9
http://www.schunk.com/schunk_files/a...162__DE_EN.pdf
Old 03-23-2008, 11:36 PM
fastening by threaded studs to DIN 55027
http://www.stimtools.cz/kat_pdf/katalog_sklicidla.pdf
Old 03-23-2008, 11:41 PM
ASA B45.9 in type A (series - A )
http://www.dimac.com.au/backplates.pdf
Old 03-24-2008, 11:33 AM
handlewanker is on a distinguished road
Hi FPV, this looks like the chuck fitting we had in the 50's on a VDF German lathe.
The lathe spindle had a loose collar behind the mounting boss and the chuck had studs with nuts and washers in the back.
To mount the chuck you put the chuck against the mounting boss and entered the studs with nuts and washers attached through the holes.
The loose collar was rotated to bring the slotted holes round and the nuts tightend up.
The last photo in post #1 shows a slotted collar at the back of the mounting boss and if this is loose then this is what the nuts will tighten up to when the collar is rotated.
The mounting boss has a slightly tapered spigot on the front face that locates the chuck for concentricity.
Hope this is of use to you.
Ian.
  #11   Ban this user!
Old 03-24-2008, 05:46 PM
hi
Thanks Ian any help is appreciated , the problem is there are so many verities of the lathe spindle nose flanges ( back plates , mounting plates , spindle nose fittings ....... etc )
Just found some more information http://workholding.com/BISONADOBEPAGELIST.htm
it is defiantly this one, German Standards Din 55027 spindle type " C " and judging from the spec sheet mine is a C-6 series , Even in the C-6 style there are a few differant types, the last picture on this pages link. http://workholding.com/BISON-SPINDLE...-L-THD-DIN.htm
This spindle nose is provided with a short tapered flange , like the American spindle nose A and D . Spindle flange has a number of mounting holes ( 3,4 or 6 ) into which the lock studs of the chuck can be inserted and locked
  #12   Ban this user!
Old 03-24-2008, 06:11 PM
Bayonet style
Hi
Since their in AUstralia these guys from www.dimac.com.au , I just spoke to the guys there and describe my lathes spindle mounting pattern and I think we were on the same wavelength and understood each other.
Mr Dimac asked questions and I gave answers and he come up with a Bayonet style backing plate B type and said a B1/6 actually.
Once again different terminology was used to describe the spindle back plate that I need as apposed to what I have located on the internet.
They said they would get back to me , no time frame just said he would get one of the sales team to work it out and get back to me if there available the backing plates.
As I'm going to adapter a 3 and a 4 jaw chucks that I already have the plates were going to be a universal style at the front which i will finish of mounting to different chucks flanges.
The critical part of the spindle mount plate is the lathe sided at this stage.
If no luck locating what I need , I have been drawing and made a spec sheet of my lathe and the two chucks I have ready to mount on the lathe. I will just have to machine my own two units from scratch time consuming.
Start of with a 40mm thick 300mm by 300mm square plate and start machining. Would be great if I can just buy of the shelve adapters save sometime.
Don't you just hate it when people dismantle equipment and fail too leave what comes with the equipment standard with it when a buy makes a purchase. Some people have no fggen idea. Sorry for the bad language just letting of some steam.
Let see what happens.
cheers
accurate chuck mounting ptxman Work Fixtures and Hold-Down Solutions 0 01-30-2008 11:21 AM
Help with mounting a new 4 jaw chuck medfoch Mini Lathe 4 08-20-2007 05:05 PM
** Please help identify Chuck Wrench for CNC lathe picture cjchands General Metalwork Discussion 10 03-18-2007 06:10 PM
Refitting servo mounting flange? Tig Mechanical Calculations/Engineering Design 2 01-06-2007 01:32 AM
Ball Nut Mounting Flange Types - Question? widgitmaster Linear and Rotary Motion 7 06-14-2006 02:28 PM
