Old 03-15-2008, 03:52 PM
lannyn is on a distinguished road
Unhappy SMC spray mist model LMC200-13
Hello everyone. I am new to this forum. I am a retired guy just messing around in my home shop. I build hot rods on a part time basis and use my CNC mill to make hard to get parts. I recently bought on Ebay a spray mist unit made by SMC. It looks like a new one, but as often happens, there is no documentation. Oh well, how hard can it be, right? There is a input for air, a cap to pour in coolant. A output connection to the sprayer, two guages showing pressure coming in and another showing pressue in the coolant tank. There is a manual button as well as a seloniod signal input. My problem is that when I activate the unit I get a solid stream of coolant from the nozzle. It would empty the tank in a few minutes if left on. I expected to get an ajustable mist, not a stream of fluid. Can anyone help me with this? Does anyone have some instructions for this unit? I think I got a good deal on it. New ones list for around $700. But..... if it won't make a mist I guess it will be money wasted. Thanks in advance for any help you might give. I have some pictures of the unit if anyone wants a look at it.
LannyN
Old 03-16-2008, 03:00 PM
*Registered User*
fpworks is on a distinguished road
I might know what the problem is. First of all, tell me about the nozzle that you're using. (post pictures if you're able)
Old 03-16-2008, 05:38 PM
Thanks for looking at this...
Here are some pictures of the unit. I am afraid they are a little blurry. The sprayer is simply a dual head type. The nozzles are just a hole in some plastic, nothing special. Are you thinking that is the problem? Is there some special type of nozzle required?
ID:	55639   Click image for larger version
ID:	55640   Click image for larger version
Old 03-16-2008, 05:41 PM
*Registered User*
Sorry, I should have been more clear. I really need to see the nozzle and mixing manifold. (external to the unit)
Old 03-16-2008, 05:47 PM
Thats all there is...
I assumed the mixing was done internally and a air/fluid mixture would be produced. If there is something more to the unit I guess I am out of luck. I feel a little silly if I am missing something obvious. Again, I really do appreciate your help.
Lanny
Old 03-16-2008, 07:48 PM
*Registered User*
Lanny,
You also need a special manifold and a venturi type nozzle to make it work...these are available if you do a search. I don't see it costing any more than $100-$150 to finish it up. You have the expensive part already.
The mixing is actually done at the nozzle.
Here you go, see the "LMV" mixing valve at the bottom.
http://www.smcetech.com/CC_host/page...A_E,Node_13061))
Old 03-17-2008, 08:52 AM
Thanks for that information. I was unable to link to whatever you posted with that answer. Something about no-cookie session..???/ I hate to be a pest but can you give me an idea of where and what to search for?
Old 03-17-2008, 08:56 AM
*Registered User*
Their website is being difficult. Go to the following link, then select "air preparation" then "lubricators"
http://www.smcusa.com/sections/products/airline.asp
Old 03-17-2008, 09:58 AM
Thank you, I think I know what to ask for now. I will call them and let you know how it works out.
CNC Spray Painting Machine billman Printing, Scanners, Vinyl cutting and Plotters 12 02-04-2010 10:48 AM
Need Help!- SMC LMC200 mister problem lannyn General Metalwork Discussion 0 03-15-2008 07:18 PM
Build Thread- CNC Spray Painting Machine xitian Printing, Scanners, Vinyl cutting and Plotters 4 03-05-2008 03:31 PM
Laser Spray PaioX Laser Engraving & Cutting Machines 2 08-01-2007 09:33 AM
CNC Spray painting ynneb Hobby Discussion 10 05-28-2007 04:49 PM
