i need to make the following conical hole using a cnc lathe. the wider diameter should be approx 5/16" and the tip diameter (inside the 2.4" hole) shlould be approx 11/64" . the material is brass. what tools can i use to meke this hole? |
| Maybe find a tapered pin or Morse taper reamer that would work for you. A Bridge & Boiler reamer is another possibility. Edit: Book on making reamers if you care to go that route. http://books.google.com/books?id=ZE0OAAAAYAAJ&pg=PA59 If you do try a boring bar carbide would be better then HSS at that depth ratio, you have the advantage in that the bar could be tapered. Use shorter bars for most of the job. Last edited by Andre' B; 03-12-2008 at 04:55 PM. |
| Tags |
| bar, boring, deep, hole, lathe |
| Deep hole drilling | kalmah | General Metalwork Discussion | 8 | 09-09-2007 10:09 AM |
| RFQ: Deep hole drilling in several materials | m-134b | Employment Opportunity | 3 | 08-23-2007 05:55 PM |
| Concentric deep hole drilling | m-134b | General Material Machining Solutions | 7 | 07-30-2007 07:45 PM |
| Can an X1 bore a deep 70mm dia hole in Al? | digits | Benchtop Machines | 59 | 03-04-2007 09:24 AM |
| Deep hole drilling on OKK | eddie | G-Code Programing | 1 | 09-21-2005 06:55 PM |
