Old 03-07-2008, 03:42 PM
stevieboy is on a distinguished road
speeds and feeds
Hi Guys,
I'm relatively new to the world of cnc machining and I'm also learning as I go along. I'm starting to use tipped tooling and I need to know how to work out the best speeds and feeds from the information given to me by the tooling supplier, Vc and Fz etc. Can anyone help.
Old 03-08-2008, 10:24 PM
blackbeard52 is on a distinguished road
Here is a online calculator....however, these ratings do not take into account your machine rigidity or material you are cutting.
http://www.americanmachinist.com/Cal...eedsFeeds.aspx
hope it helps
Bob
Old 03-09-2008, 10:55 AM
*Registered User*
Bluesman is on a distinguished road
Here is a habit I got into years ago, I got tierd of figuring it out based on the tool suppliers recomended SFM so I came up with this. Then I cane change the SFM at will to get optimum perfromance from the tool and not have to refigure the rst out.
O8315(T31 DRILL 14.06)
G0G17G21G40G49G80G90G94G98M11
#1=350(SFM)
#2=.006(FEED/TOOTH/REV-INCHES)
#3=.554(CUTTER DIA-INCHES)
#4=2(NUMBER OF FLUTES/TEETH)
#5=ROUND[[#1*12]/[#3*3.1416]](CALCULATED RPM)
#6=[[#4*#2*#5]*25.4](CALCULATED FEED MM/M)
#999=#6
IF[#1005EQ1]GOTO1100
M07
T#20
(L3 B315.0)
#519=7
M98P8705
M11
G90G0G54X-24.3Y0.B0.S#5M3(CALC RPM)
M10
G43H31Z69.89
G01Z67.0F[#6*.25](SLOW FEED TO START DRILL POINT)
G1H81Z68.89F#6 (CALC FEED)
G0H131Z41.56
G1Z42.56F#6
IT HELPS SAVE ME SOME TIME,
BLUESMAN
speeds and feeds bdrmachine SolidCam 6 04-12-2008 09:15 AM
Need some help with speeds & feeds ldkell_2000 General Metalwork Discussion 6 03-01-2008 11:35 AM
Help! with Feeds and speeds please! sjotime! Visual Mill 3 02-13-2008 01:56 AM
feeds and speeds porkchop21 Bridgeport and Hardinge Mills 2 08-30-2007 08:52 PM
Speeds and feeds Hack General Metalwork Discussion 2 10-15-2005 11:47 AM
