Well, it may sound silly but all Ive turned in my Leadwell LTC-15 is stainless steel and tool steels with moderate tolerances (.005). I havent done any 6061 aluminum yet, and I am wondering what kind of tooling I should use. I was told to use High Speed Steel to turn it, for a nicer finish. The part im making has a .0004 tolerance, so I could use some help as far as speeds and feeds go as well. Like I said before, no experience on this type of material, let alone with such a small tolerance. Am I headed in the right direction with the HSS on this or not? Anything to set me straight would be appreciated. Thanks. |
| You can use uncoated carbide and it is possible to get inserts with a grind specially for getting a good finish on aluminum. Your tolerance is tight for aluminum. Linear expansion per unit length per Deg F. for aluminum is 0.000012 so you really need a temperature specified for doing the measurement.
| I use solid carbide positive rake inserts. They are made for aluminum. Aluminum is soft and a non-sharp tool tends to push it rather than really cut it, and chip control can be a PITA, but the positive inserts help. |
| Machining aluminum honeycomb | Making chips | Composites, Exotic Metals etc | 4 | 06-03-2008 12:23 PM |
| Aluminum machining quote | mcraig79 | Employment Opportunity | 0 | 09-23-2007 10:39 PM |
| Question about machining aluminum | djmachinist | Benchtop Machines | 5 | 10-28-2005 07:27 PM |
| Machining L168 aluminum | laamar | General Metalwork Discussion | 2 | 01-30-2005 05:31 AM |
| machining aluminum castings | donj1 | General Metalwork Discussion | 9 | 11-05-2004 07:12 AM |
