Old 03-04-2008, 02:30 PM
hiatec is on a distinguished road
Using the touch-off probe in a Johnford Lathe 650A.
Hello,
I want to use the touch-off probe in a Johnford Lathe 650A; but I have not figure out how to activate it (I don't have the manual). Somebody can help me with this?
Thank you very much.
Old 07-08-2011, 02:22 PM
InkStain4Life is on a distinguished road
not sure if this will work but we have a bt-40 lathe and heres how we do it. select your tool needed to touch off, go to the offset screen, next(I think its the + screen key) then press the OPR screen key there should be a list of options here that allow you to turn on the post. and should auto matically take you to the geometry screen for tool lengthnote that you only need to turn it on after lowering post. handwheel tool close to stylus then go to jog mode and use axis direction buttons to feed into stylus when tool is touched off light should turn red
touch probe and Mach3 devincox Mach Mill 13 02-15-2010 09:58 PM
k2CNC 3D Touch Probe Mike Stevenson K2CNC 0 02-14-2008 01:44 PM
Touch probe indexing carving1 WoodWorking 0 07-22-2007 03:03 PM
Touch probe for sale cut more Digitizing and Laser Digitizing 2 03-08-2007 06:50 AM
Touch Probe for a Noob. lilricky2 Digitizing and Laser Digitizing 26 02-02-2006 05:04 PM
