Old 03-03-2008, 05:48 PM
bbrreid is on a distinguished road
TIPS FOR TURNING ALUMINIUM CAST
can someone recommend a good grade of "V" shape tips and speeds and feeds for turning 30mm diam cast aluminium alloy grade LM24 removing 1mm a side for 28mm diam with a 0.5 to 1.5 surface finnish. I am hoping to use one pass as there are hundreds to do on my old Yamazaki cnc lathe max spindle speed 2000 rpm
BR
Old 03-18-2008, 03:41 PM
pgstools is on a distinguished road
Were you able to sort this out?
If not you may want to consider a C2 uncoated carbide insert or something that looks like this:
Only in a V style.
Send me a PM if you have any questions.
PGS Commodity Supply
www.pgstools.com
Old 03-18-2008, 06:38 PM
Thank you for the reply. I got lucky and found tips on ebay that were used
on alloy car wheels and seem to be working out fine. type vogt180610
i am looking into using a diamond tip for the finnishing cut if we have to better the finnish
BR
Home cast Aluminium CNC KrashKing405 DIY-CNC Router Table Machines 2 11-21-2007 07:53 AM
anybody compare HT finecut tips to TD 1Torch tips for dross? Knut CNC Plasma and Waterjet Machines 0 09-29-2006 02:17 PM
Tips for turning Titanium? warpedmephisto General Metalwork Discussion 3 05-08-2006 01:13 PM
Drafts: Tips for vendors and tips for RFQ writers... InspirationTool Employment Opportunity 3 12-20-2005 09:44 PM
need help w. first cnc part. need tips!! xknacx General CNC (Mill and Lathe) Control Software (NC) 7 11-19-2004 09:06 AM
