Hi, I would like to know what you guys think of this indexable end mill? Please keep in mind it will be used in a hobby environment for one's and two's not production work, cutting 12L14 (ENA1) steel and aluminium. http://cgi.ebay.co.uk/16MM-INDEXABLE...QQcmdZViewItem Do you think it will end up in a draw never to see the light of day again? Should I spend more on a known quality brand? Thanks for any input, ![]() John Last edited by Oldmanandhistoy; 03-03-2008 at 05:35 AM. |
| A couple of things to consider. First, at 16mm = about 5/8", for me, that would be a bit marginal for a straight end mill. The reason? Because a regular 1/2" endmill will do just about everything that one will and more for a lot less money. True, you have to replace it or sharpen it periodically, but there's more flexibility. I prefer to get larger, say 25mm/1" before I look at an end mill like this. Second, for indexable tools, geometry and insert design matters a lot. I won't buy one unless I can determine that it has high positive rake geometry. I went looking on this one to try to see if I could find that info on the web, and couldn't find any indication one way or the other. Positive rake will give lower cutting forces which is better in most cases for the home shop machinist. The only advantage of negative rake tooling is longevity and sometimes being able to use more edges on the insert (largely a factor for lathe tooling). I prefer to spend more money and get a larger, name brand, indexable mill with definite positive rake. If you look long and hard, you will eventually find one. Don't be afraid to look on US eBay either--shipping for such a small piece of tooling will be minimal. I own a 1" Iscar Helimill that's a fantastic little cutter. I also have a Lovejoy facemill that's 3" and is my favorite for all but final finish. The finish is fine, but I like the look of a single pass, so I use a fly cutter on the last pass for anything over the 3" width my Lovejoy will handle. Both of these are positive rake. That brings me to my last point. Be sure to price inserts before you buy a cutter. My Lovejoy face mill was brand new and sold by Lovejoy themselves on eBay. The downside is new SPEX inserts are hard to find and not cheap. I hope this has helped. Best, BW |
| nothing wrong with that price , for the price of the inserts alone you are more or less getting the tool for free MITSUBISHI isnt junk as for your question , your the only one who knows if it will be sitting in the drawer
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
My mill only has 1.3 HP (1000 watts) and the largest recommended end mill is only 16mm but I am unsure how this would apply to an indexable? That’s good to know thanks I am happy to buy from the US so will do a world wide search but in the mean time if any one would like to make a recommendation on a reasonably price quality tool I am all ears. Any links would also be appreciated. ![]() Thanks, John |
| Hi: For home/hobby use indexable tools are a waste of money (in my opinion). It's nice to have some indexable facemills for bigger jobs, but for C12L14 id just stick to HSS. The whole purpose behind indexable tooling is for production, where when last I checked the average life expectancy of an insert was 15 min of service. I'm not trying to flame you, but indexable tools really are designed to "fly", and for the size of the mill described, I'd recommend sticking to HSS. just my 2c cents cheers |
???? index tools will fly or hog ive run them for hrs if not days under full production without changing an insert running hss in my opinion is a joke ,carbide is the way to go , if your resourcefull they don t cost much at all
Thanks for your time ![]() John |
#10
| I think a good reason for indexable even for a hobbyist with an under powered mill is that with Ebay insert prices it would work out cheaper than buying standard carbide end mills. Might be wrong ![]() John |
#11
| I don't know what mil you have, so I can't advise whether you would have use for a bigger end mill. Which model is it? RE number of degrees of positive rake, that's going to be very application specific. You can get the rake from either the way the insert is mounted or the insert itself. Very often it is a combination. I'd ask the seller to point you to the manufacturer's web page for the end mill. Take a look there and just see if positive rake is mentioned. For example, here is the Lovejoy facemill page I mentioned: http://www.lovejoytool.com/f225.htm It mentions both the positive rake and goes on to say, "ideal for small and light duty machines in general purpose applications." That's us home guys! Most of the manufacturers will make such a mention. Your 12L14 leaded steel should be very easy to machine, BTW. You won't need the last word in cutter technology to do it. Nevertheless, eventually you'll want to cut something else. And I would definitely not discourage carbide on these small machines. It works great. Best, BW |
#12
I will ask for the manufactures website and see what comes up. Seems to be a good price after a little further searching but that may be reflected in quality. I’m a wood machinist by trade and know what difference quality tooling can make especially on lighter machines so believe the same would be for milling metals. Thanks again, John |
| Used VF2 possible purchase, just a few ?'s | JMFabrications | Haas Mills | 21 | 04-01-2011 01:34 PM |
| Best purchase? | cnc@52 | Milltronics | 17 | 10-09-2007 03:19 PM |
| Looking to purchase a new Vf1 | DRD | Haas Mills | 12 | 09-13-2007 06:06 PM |
| want to purchase a CNC from anyone | corbyvhall | Benchtop Machines | 1 | 03-24-2005 08:08 PM |
| V19 purchase | converterk | BobCad-Cam | 4 | 10-01-2004 09:17 PM |
