  #13   Ban this user!
Old 03-01-2008, 10:39 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Originally Posted by Geof View Post
It was a length of flat bar, I did say you could consider it a sub-table.
Your OTOH explains its purpose exactly.
The reason to not use vises was we didn't have any big enough, the part was eight inches wide. Also with vises the accuracy of repositioning is going to be limited by the accuracy of the outer edges of the part.
I get it. I suspected it had to do with size. The accuracy of repositioning issue is why I want the vises to grip area that is already true.
Thanks for your thoughts.
Best,
BW
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 07:56 PM
Z axis length for 4'x8' router mill wcarrothers DIY-CNC Router Table Machines 10 08-20-2006 08:29 PM
A Mill for milling HSLA and Mild Steel deep_drill General Metal Working Machines 3 06-06-2005 11:29 PM
