I have access to a woodworking miter chop saw in a workshop at the program for mentally handicapped people where I work. Do I need different kind of blade for cutting aluminum on the miter chop saw? I will be cutting aluminum angles and flat bars and maybe small sheets for a CNC machine that I will be building using plans from Solsylva. Do I have to use the drill press running at a slow speed to drill holes in aluminum? Can I use hole saws and Forstner bits? Should I build all the wooden parts first before building metal parts so that the wooden parts can be painted? |
| If you're not cutting a lot of aluminum, any good carbide blade will work. If you are cutting a lot, get a negative hook triple chip blade.
| Cutting Aluminum | bossfrog | DynaTorch | 8 | 07-07-2008 10:21 AM |
| Cutting Aluminum | darylprice | DIY-CNC Router Table Machines | 7 | 07-03-2006 11:51 AM |
| K2 cnc Aluminum Cutting | Ed Williams | General Metalwork Discussion | 0 | 03-16-2006 01:38 AM |
| Cutting aluminum | rocks101 | DIY-CNC Router Table Machines | 5 | 02-27-2005 02:29 PM |
| Aluminum Cutting | Tazzer | DIY-CNC Router Table Machines | 5 | 07-29-2003 01:09 AM |
