Hi Guys, For those of you that have converted their mill to CNC and have used a 5/8" ball screw what size angular contact bearings did you use? I was thinking of use VXB P/N 7201B 12x32x10. Can I use a 15x35x11 size bearing or will I have to cut down the ball screw too much (smaller diameter that 15mm). For the support end, do I just use a sealed standard bearing? Thanks, skipper |
| conversion ballscrew pics: Another X2 CNC Conversion (yay!) |
| I was thinking about a 3/8th size thread with a nylon insert. Just because I've already removed my lead screw and was going to use a thread die. That lock nut looks so good I may just have to re-assemble my lathe and single point thread it. Cheers, Jack Edit: Found a .391-32 thread die. It must be made of gold... Mcmaster, carbon steel #2619a71 is $47 or High speed steel #2619a31 is $70.
__________________ Walking is highly over-rated |
| Angular Contact Bearing Confusion | skipper | Linear and Rotary Motion | 9 | 11-08-2007 07:07 AM |
| Angular contact bearing question | Rube | Benchtop Machines | 19 | 09-20-2007 12:14 PM |
| Tapered roller bearing vs. angular contact bearing | boyvox | Linear and Rotary Motion | 12 | 01-25-2007 03:49 PM |
| Angular Contact Bearing Spacing? | ngr1 | Benchtop Machines | 33 | 12-20-2006 07:44 PM |
| Angular Contact Ball Bearing ? | sendkeys | General Metal Working Machines | 2 | 06-24-2004 03:06 PM |
