| how do you machine this notch out? <img src="http://www.replicaprops.com/notch.jpg"/img> |
| My guess would be wire EDM or use a Broach. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| You can broach it.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| Well if you do not have a EDM or a broach in your basement I have drilled the slot with a 1/32 undersize and then file the corners in, this works if not a great deal of precision is needed, but if you are careful it can be that to.BTW, if the large center bore is already there then the drill wont get it but taking your time you can file it. You could plunge mill the slot and then file. Ken Last edited by Ken_Shea; 07-21-2004 at 09:23 PM. |
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| LOL Rekd, another useful tool those precision spindles make is a great quick arbor press |
| If you have the room, you might be able to drill the inside corners first to remove the radii and then mill out. Or simply add an overcut in the corners as shown. The dia of the overcut is slightly larger than your bit. |
| Good idea Buscht, I will try and remember that. replicapro, let us know how you ended up doint it. Rekd I will admit that in a rush having done that on my old import bridgeport style mill where the precision beraings are not all that precision even when new, but it wont happen on my Haas for sure. Hey, on a CNC you could get a running start using rapids for those really tough press fits |
#10
| In the olden days, I occassionally cut a keyway with a HSS square bit held in a boring bar in the lathe toolpost. I would "rack it by hand". Predrilling or roughing with an endmill helps a lot prior to doing this. ![]() But for small work, broaches and a large arbor press will serve well, if you want to make the investment in the arbor press. It takes a so called "5-ton" arbor press to give you much usable depth for the work and the broach to fit beneath the ram.
#11
#12
| Hu to the rescue!!!LOL!!!! I have done it like Hu described! It was to recut the undercuts on the commutator of my car's starter motor. It's very effective, a little time consuming however...... Klox
__________________ *** KloX *** I'm lazy, I'm only "sparking" when the EDM is running.... |
| CNC Glossary | CNCadmin | CNCzone Club House | 17 | 03-09-2008 04:08 PM |
| My First CNC Machine, Mr. Chips | Mr.Chips | DIY-CNC Router Table Machines | 81 | 02-10-2007 10:04 AM |
| Confused about CNC software | samualt | General CAM Discussion | 22 | 06-30-2005 09:18 PM |
| Heads Up - Article about building CNC Milling Machine | samualt | CNCzone Club House | 3 | 06-13-2005 03:43 PM |
| FeatureCAM Expands Product Offering with Machine Simulation | CNCadmin | Product Announcements & Manufacturer News | 0 | 01-21-2005 07:58 PM |
