The mill spindle is R8, and I want to mount a 3" or 4" chuck in it. I can't find any type of mount for a chuck, but I'm not sure if I just don't know the correct keywords for whatever I need for this? My other thought was to machine a mount plate that's essentially a disk with a 3/4" shaft on it, and the shaft would go in a 3/4" R8 collet in the mill spindle. The chuck would then get bolted to the disk part. But if I can find a ready-made solution I'd prefer that route. Ideas, thoughts, pointers? Thanks, -Neil. |
| Your plate on a 3/4" shank idea is probably close to the best; the only change that might make it more rigid is to use a face mill holder and make a plate to fit this. There have been a few threads about putting a chuck on a mill spindle and I don't think anyone found a ready made solution. Here is a link that takes you to one thread, these are dealing with larger size CNC mills: Using a CNC mill as a lathe And here is one I did for fun which shows what is possible: http://www.cnczone.com/forums/showth...398#post406398
| There's a guy on e-bay selling 3" and 4", 3 jaw chucks that have an r8 taper. Price was pretty cheap too. http://cgi.ebay.com/BRIDGEPORT-R8-SH...QQcmdZViewItem Paul |
Dibs!!! |
| So I picked up one of these from an Ebay seller for $40 -- a 4" chuck with an R8 mount. I wasn't too thrilled by the seller, but the product is decent. I did not slip smoothly into the R8 spindle on my mill, but it wasn't too bad -- I just had to pull it up with the drawbar. But the main purpose was met -- to do some CNC turning on my mill. Pretty neat! I should measure with the dial indicator to see how concentric it is though. Thanks, -Neil. |
| Sweo spindle drive? new mill dead spindle | Shizzlemah | Fadal | 13 | 12-18-2008 12:11 PM |
| Spindle Chuck Questions | SPEEDRE | DIY-CNC Router Table Machines | 5 | 01-19-2008 01:28 AM |
| Tool Mount For Jacobs Taper 3 mount | pzzamakr1980 | Tormach PCNC | 5 | 03-29-2007 03:31 PM |
| How do I remove a kwik chuck/spindle | Andyh | Bridgeport and Hardinge Mills | 1 | 08-14-2005 01:28 PM |
| manual mill Z axis conversion mount | Bryscnc | Bridgeport and Hardinge Mills | 3 | 04-04-2005 06:10 PM |
