Hi fellas, I need a hand finding out what insert i need. I found a very nice indexable milling cutter that was crashed at some point but now repaired. unfortunately all markings/etchings of any kind were grit blasted off during its repair and now refinished. i have no clue as to the maker of the cutter. Here's what I do know.... Cutter has a 7/8" shank with a 1" cutting head. OAL is 3.75" 3 inserts that appear to be an APKT type insert or simliar. The insert has a thru hole of .130" and is countersunk for the retaining screw. the top of the countersunk hole in the insert has a .180" counterbore for the retaining screw head. the retaining screw uses a T9 torx wrench to tighten the insert into the pocket. . The width or IC of the insert is .3125" the length is .520" thickness is .150" the insert has a positive rake of about 15deg. and a chip breaker in the face. Anyone have a comprehensive technical book or link to a webpage that shows this insert so i can put it back into good use?? I'd hate to have to trash it just because of lack of inserts. Any help appreciated!!....Thanks. |
| Hope this link works. https://www.travers.com/scripts/cgii...VE40/login.htm Page 358 and 359 for Iscar 1003 and 1505 Page 380 for Valenite's V590 stuff Page 382 for Valenite's spectramill Page 404 and 405 for T&O's Iscar copy The Travers master catalog is a good one to have a paper copy of, lots of info. |
I looked in the pages of travers and the sizes I need are not listed, the insert style is the same, but the thickness, width, and length of the insert is not listed......... MORE HELP PLEASE!!! |
http://www.lakesideguns.com/webstuff/carbidemill.jpg ![]() Here's a pic of what I have. Refer to the dimensions above for the info....... I might have to post a reward for the winner... |
| Try Korloy inserts. Look like regular uncoated positive rake for steel etc. I've got lots of these from Korloy http://www.korloy.com/eng/e_mainF.html regards |
| Well, i went to the iscar site and there is no designation for a .3125 wide 85 degree paralellogram insert...there is 3/8" wide and .264" wide...but nadda on the type i have. the geometry of the cutting face appears to be iscar.......but I can not find the size anywhere!!! HELP!!! need more help here fellas.....this seems like an extinct insert for some reason....???? |
I'm still looking for this insert designation so we can buy replacements. I'm getting desparate here....hows $5.00 sound for the first guy who can get me the correct insert designation for replacements????? |
#12
| dertsap....i think you may be the winner!!!! Ingersol does show an insert designation chart in their site that shows the dimesnsions of the insert i need.... apparently one style is the APKT 1203XXR that will work....... How do you want your reward???? ![]() |
| Long end mill needed desperately | laripper | CNC Tooling | 0 | 12-04-2007 09:55 AM |
| Insert Milling Tools? | Joseph Souza | General Metalwork Discussion | 11 | 10-18-2006 09:26 PM |
| Newbie question - need help desperately | DanteMancino | Mechanical Calculations/Engineering Design | 3 | 10-02-2006 09:50 PM |
| Desperately NEED HELP FOR SCHOOL PROJECT | Epik | General CAM Discussion | 4 | 12-09-2005 06:06 AM |
| 2 parts needed: gear and insert | SimonArthur | Employment Opportunity | 4 | 03-12-2005 05:20 PM |
