#13
3003 should be a good candidate for the step drill. I wouldnt think you will have any problems with burring or pullup. As mentioned earlier, I would at least predrill some holes for fastening as .040 thin material will flex and the holes will remove clamping bars from the work area. I would support the cover on a board so that any burring will be on the inside surface and will be easily removed with a deburring tool. I would drill in the areas where the slots will be machined as I mentioned earlier. and after a tool change it will go very smoothly without the aformentioned disk left behing by the endmill during the plunge cut. Good luck Bob |
| Deep Groove Taig machine would it be a good starter machine | Fritzie15 | Taig Mills & Lathes | 0 | 09-20-2007 09:37 PM |
| Use Machine Shop vs. Buying Machine | imp22b | General Metalwork Discussion | 15 | 06-06-2007 06:33 AM |
| G Code Variances from machine to machine? | Miguel Gonzalez | G-Code Programing | 16 | 03-28-2007 03:31 AM |
| Mach 2 on old machine = great machine | foamcutter | Machines running Mach Software | 6 | 12-16-2005 12:11 PM |
| Getting work(gcode) from machine a to machine b | strat | DIY-CNC Router Table Machines | 9 | 07-07-2005 02:13 PM |
