#13
| Thanks Gary The Manual arrived safely, I will try out some 3D practice pieces using wood as I try and get my head around how it works I have nearly finished the first pair of rocker pillars machining manually, but I will not be able to complete the second pair until I collect the cylinder head next month as there is an issue with the thread size on it Regards John |
#14
| The Mastercam website has an MX3 post available for download, free. Just click on posts, then at the right side of the page "V9 educational archive". To mill a 4 x 3 block, just use the subroutine repeat function. For example, mill across the upper portion of the part, then repeat with Y minus something less than the cutter diameter. |
#15
| Thanks for that leftcoastlefty, I have had not had much time to study the MX3 manual sent by Gary yet. earning a living gets in the way of home workshop time!!! My next parts to make are in the drawing attached, I hav'nt decided yet whether to machine them or to make patterns and get them cast All ideas and suggestions welcome Regards John O Regan |
#16
Kevin, my company is new to the machining world and we are in the market to purchase a 3 axis cnc bed mill. We are currently looking at the TRAK FHM5 w/h the Proto TRAK SMX CNC controller. Do you know anything about this machine and if not what would you recommend to purchase? Thanks, Dave |
#17
Hey I cannot figure out how to start a new thread, this website is either terribly laid out or I am impatient. Anyway, a machine shop in my school recently aquired a Chevalier milling machine with a Proto Trak M2 Digital readout and axis-controller. I was wondering where I could find a manual for this readout, just a general user's guide so we could understand how to work it. Thanks! |
#18
| The proto trac software is pretty easy to use just try different events and try to be postive, its a lot easyier than putting and taking off a rotory table try doing some small programs and using the trail run and show path i have been using them for since the early 90,s |
#19
| Hi You should be able to get the manuals from the manufacturers, http://www.southwesternindustries.com/swi/ There are lots of different versions of the prototrak systems Regards John |
#21
#22
I have a ProtoTrak AGE-2 controlled knee mill at home. I do the majority of my designing and redrawing in Esprit. I'll get the points and use the "Math Help" when the machine doesn't like a number. Here are some parts that my machine has made. I'm making parts for a friend's live steam locomotive in stainless and most of these pics are of those. The aluminum part is a rocket nozzle for a re-enactor friend. I made 6 of these for him... I also have access to a Trak K-2 with the SMX control at work. I bought the AGE-2 so I wouldn't have to make parts for friends at work and get myself in trouble. Andy Pullen
__________________ Clausing 10" x 24" lathe, ProtoTrak AGE-2 control on Sharp knee mill, Sheldon 12" shaper, Reed Prentice 14" x 30" lathe |
| PROTO-TRAK | Gary55Ford | Fanuc | 2 | 01-25-2008 06:47 PM |
| Gibbscam post for proto trak M2 | mmarriott | Post Processor Files | 0 | 10-25-2007 09:49 AM |
| Proto Trak? | Garage Shop | Bridgeport and Hardinge Mills | 5 | 01-31-2007 10:38 AM |
| BP Proto trak plus questions | Bruce Griffing | Bridgeport and Hardinge Mills | 0 | 01-07-2007 11:12 PM |
| RFQ 2 Op CNC Milling (Proto) | Spike_TDI | Employment Opportunity | 4 | 04-27-2005 06:36 PM |
