Old 02-02-2008, 05:21 PM
mooreaa is on a distinguished road
What tools to use for Gear making?
Hello,
I am interested in cutting custom gears and was wondering if someone could give me some advise on what tools would be best for cutting them.
I want to be able to cut either aluminum, nylon, or similar plastics. The gear types would mostly be bevel gears, face gears, regular pinion/spur gears.
I am in the market to buy a new CNC machine but I am not sure if a CNC mill itself is sufficient in cutting gears. I am looking at a Tormach to fill my flat plate milling needs. I am not finding a lot of info about how to cut bevel gears with a CNC.
Any advice/recommendations would be appreciated.
Old 02-03-2008, 01:30 PM
mooreaa, Milling machines, both manual and CNC, can cut gears. Not all gears, but many types of gears. Straight bevel gears yes, spiral bevel's no.
Straight bevel gears are cut on a milling machine with a form cutter and the workpiece held in an indexing device, positioned at an angle if a manual mill. Spur gears require an indexing device with appropriate form cutters.
Volume of production and cost determine justification unless it's a hobby thing. If it's a hobby decision, no logic need be applied. LOL
Dick Z
DZASTR
Old 02-03-2008, 05:32 PM
Thanks Richard.
Thats good to know that I can cut straight bevel gears with a mill.
Where can I find more information on this? I have seen a lot of info on how to cut spur gears, but not straight bevel gears.
Can you recommend any tools or sites?
I have been playing with Rhino trying to design a bevel gear, but I am having difficulty getting the gears to mesh well. If you could recommend some reading on bevel gears I would greatly appreciate it.
This is for prototyping, not production so volume production isn't a factor at this time.
Old 02-03-2008, 08:25 PM
mooreaa, The source for how is "Machinery's Handbook"(spelling is correct) and cutters described there are available from many sources including Ash
There are many "how to" books, but mine (I'm old) is The Cincinnati Milling Machine Co.'s "A Treatise on Milling and Milling Machines" for conventional machines. This will supply the basics. Others on the Zone can provide the CNC "how to's". I would consider linear interpollation for the bevel angle with an indexer to provide tooth spacing. The indexer could be a simple indexing fixture as in the manual method or a 4th. axis.
Dick Z
DZASTR
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 10 04-05-2012 09:55 AM
Bring your own tools or does your company supply tools? ZipSnipe CNCzone Club House 10 02-04-2011 07:06 PM
gear making tool or wizard of some sort Craigpat Solidworks 2 01-22-2008 12:39 AM
Spur Gear / Gear Rack ckrantz Linear and Rotary Motion 12 12-06-2006 11:06 PM
Gear PROBE General Electronics Discussion 0 03-14-2004 05:11 AM
