Old 02-01-2008, 10:43 AM
Smrtman5 is on a distinguished road
M2 Steel & an Endmill Question
Two things were told to me today which i didnt believe and i wanted too see who was correct.
1. I ordered a M2 hss lathe tool blank from mcmaster. The shop tech said that it could not be ground and it could only be EDMed. I couldve sworn i have successfully ground these several times before. Can you grind M2 tool steel on a non-diamond wheel?
2. are endmills case hardened?
Old 02-01-2008, 10:56 AM
keebler303 is on a distinguished road
1. yes they can be ground quite easily.
2. not sure but it would make sense. Hard cutting edge and ductile core.
Matt
Tags
tool steel
ok total newbie question i have looked hard & everywhere for carbon steel stevef12005 Rockcliff Machine 4 12-08-2007 10:47 AM
Shorten My Endmill DroopyPawn CNC Tooling 4 11-12-2007 06:05 PM
Steel Tubing specification question ad_bfl Mechanical Calculations/Engineering Design 1 10-24-2006 04:31 PM
Simple question: Hot roll vs cold roll steel CuttersCov General Metalwork Discussion 1 02-16-2006 07:38 PM
3/8 Ball Endmill in Tool Steel Freddy Hard and High Speed Machining 2 09-08-2003 03:13 PM
