Old 01-30-2008, 10:10 AM
rbest27 is on a distinguished road
3/4 endmill, 4" necked back
It's a carbide endmill, destiny viper to be exact. I'm going to be doing a pocket about 3.5 inches deep. I'm looking for depth of cut and speeds and feeds. Material is 6061.
Old 01-30-2008, 10:54 AM
First comment; thanks for the name Destiny Viper...I found their website and am going to look into getting relieved neck mills for deepish hole interpolating that we do.
Regarding your question; is it a circular pocket, recangular, or an irregular shape, are you just going straight in with the mill, no pilot hole, if it is circular what is your size? These can influence how aggressive I would be.
As a reference for a circular pocket without any pilot hole my initial conditions would be:
8000 rpm, Z advance per circle 0.2", tool engagement up to 80% of its diameter, feed 80 to 100 ipm provided I didn't run the spindle load too high.
For a rectangular pocket the conditions would be similar and I would ramp down in some place where the horizontal travel was about 5 times the Z movement.
Old 01-30-2008, 11:59 AM
Only have a 7500 rpm spindle, but it is a rectangular pocket. I was planning on drilling a nice big hole for it to start in....reduce that ramping in time. Destiny makes them in 2 flute and Hanita's make them in 2 and 3 flutes. Sounds like i'm just going to have to see how much I can make the machine shake.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
G320 "common" or "+5vdc" why do they vary? beezerlm Gecko Drives 3 01-12-2008 04:00 PM
Slotting Titanium 3/16" Endmill TZ250 General Metalwork Discussion 6 12-10-2007 05:21 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 09:33 PM
Sqealing .75" 6 flute endmill jderou General Metal Working Machines 3 03-13-2006 07:48 AM
