Old 01-28-2008, 11:07 AM
bowersjack is on a distinguished road
Center Drill Drill Depth
Does anyone know of a chart or formula to help me find drill depth for KEO combined drills and countersinks to give me a finish countersunk hole in my programming? Or do you use spotting drill instead? Thanks Jack
Old 01-28-2008, 01:22 PM
They call them 'combined drills and countersinks' but they have a 60 degree taper on the 'countersink' part which is not correct for a flat head countersunk screw. Right now I can't remember exactly, but the angle for a countersink is 87 or 89 degrees so even a spotting drill at 90 degrees is not exactly correct. I have been told it is possible to get spotting drills with the correct angle but have never seen them; for non-critical work the 90 dgrees is often okay. Using a spotting drill also gives the advantage that you can spot for the hole location to stop the drill wandering on entry, and go deep enough to leave the countersink at this step; saves a bit of time on multiple holes.
Old 01-28-2008, 05:02 PM
mixdenny is on a distinguished road
The SAE standard is 82 degrees. Aircraft standard (thin panels) is 100 degree, although you don't come across these very often. Metric flatheads are 90 degrees. I have lots of 82 degree countersinks, but only a few 90 degree for the occasional metric job.
Dennis
Old 01-28-2008, 05:10 PM
Originally Posted by mixdenny View Post
The SAE standard is 82 degrees.....Dennis
Thanks, I try reciting that to myself a few times .
Old 01-28-2008, 08:53 PM
cnc-king's Avatar
cnc-king is on a distinguished road
may be this will help. this is a table i created when i first started in the trade before the days of excel
If you can ENVISION it I can make it
Removal of the drill press depth stop threaded rod devinchi Shopmaster/Shoptask 4 03-14-2010 09:10 AM
Brother TC-211 CNC Drill Tap Center chakrind General Metalwork Discussion 5 09-22-2008 03:47 PM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
Problem with drill depth Alan S Post Processors for MC 2 11-03-2005 02:23 AM
Do I need to center drill? jderou General Metalwork Discussion 9 06-15-2005 09:33 AM
