Old 01-25-2008, 11:55 PM
cnczoner is on a distinguished road
What am I getting this effect?...
Hi all,
This was a finishing pass taking 0.010" off the perimeter of this part with a 0.5" dia M42 cobalt endmill at 1500 RPM and 5 IPM. What's very odd is that the straight sides have a very nice finish, but around the rounded sections it looks like scallops or scales and also looks like the curve was interpolated with a low number of straight edges. You can ignore the "dent" at the cardinal point as I need to fix my backlash compensation settings.
Thoughts?
BTW, I'm using the G02 circle code in Mach 3 and wondering now if there is some setting the makes it interpolate a circle with a certain number of divisions. I'll go investigate that in the meanwhile.
Cheers,
-Neil.
Old 01-27-2008, 09:23 PM
Surely someone here knows...
Old 01-27-2008, 09:37 PM
Gold Member
Ken_Shea is on a distinguished road
Neil,
Well I guess "knowing" is a relative term, however, if that were on my machine that little divot in the center would be very disturbing, perhaps excessive backlash in the ball screws, something loose ???, I believe Mach III has software compensation for backlash. The little cutting segments leading up to that could be from too low a tolerance setting.
Ken
Old 01-27-2008, 09:38 PM
HuFlungDung's Avatar
Moderator
It does look like an interpolated arc, but if your gcode used a G02 then it cannot be the fault of the code.
Is this a stepper driven system? How many steps/rev are you using? A coarse setting there will likely show up as a facetted circle.
What quality is your axis drive system? Is it a ballscrew?
Old 01-27-2008, 10:04 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Post a copy of the program.
Stefan Vendin
Old 01-27-2008, 11:21 PM
Ken, I started tweaking the machine and seem to have reduced the backlash, but had not decreased the backlash compensation in Mach 3 yet, so I'm not worried about the divot because I know what it is.
Hu, it's an acme screw, and it has a backlash adjustment screw, but I haven't properly eliminated the backlash yet (until I make an extension for the allen key so I can get in there). See this photo... http://narwani.net/neil/mech/X-Axis_Screw_Nut.jpg
Stepper driven, with many thousands of steps per inch, because the belt drive has a 1:10 reduction IIRC (so 10 stepper steps makes one acme-screw step). I need to check on that machine tomorrow for the actual numbers. Yes, G02 and G03, but perhaps some setting I have in Mach 3
Mitsui, it's hand-written g-code. Here's the finishing pass snippet...
(----- Profile outside -- 0.1" steps -----)
G01 Z2 ( Clear over top )
G01 X0 Y-2 F30 ( Clear of material )
M6 ( Load 0.5-inch finishing endmill )
T03 ( For CNC simulator )
G01 Z0.1 F30 ( Over top of material )
G01 X7.25 Y0.625 F30 ( Start point on R.H.S. )
G01 Z-0.1 F1 ( Plunge 0.1 inch )
G02 X6.375 Y-0.25 R0.875 F5
G01 X0.625 F5
G02 X0.625 Y1.5 R0.875 F5
G01 X6.375 F5
G02 X7.25 Y0.625 R0.875 F5 ( End on center of R.H.S. )
G01 Z-0.2 F1 ( Plunge 0.2 inch )
G01 X0.625 F5
G01 X6.375 F5
G01 Z-0.3 F1 ( Plunge 0.3 inch )
G01 X0.625 F5
G01 X6.375 F5
G01 Z-0.4 F1 ( Plunge 0.4 inch )
G01 X0.625 F5
G01 X6.375 F5
G01 Z-0.5 F1 ( Plunge 0.5 inch )
G01 X0.625 F5
G01 X6.375 F5
G01 Z-0.6 F1 ( Plunge 0.6 inch )
G01 X0.625 F5
G01 X6.375 F5
(----- Full depth at once finishing pass, 0.010 inch into side -----)
G01 Z-0.65 F1 ( Plunge 0.65 inch, through complete depth )
G01 X7.24 Y0.625 F5 ( Cut in a bit )
G02 X6.375 Y-0.24 R0.865 F5
G01 X0.625 F5
G02 X0.625 Y1.49 R0.865 F5
G01 X6.375 F5
G02 X7.24 Y0.625 R0.865 F5 ( End on center of R.H.S. )
(Return to home)
G01 X7.25 F10 ( Clear away )
G01 Z2 F30
G01 X0 Y2 F30
Old 01-27-2008, 11:32 PM
I suggest you change your start point to the lower straight part of the piece instead of in the middle of the curve.
Stefan Vendin
Old 01-27-2008, 11:43 PM
Stefan, I did that so that it would break off closest to where it was clamped. I'm guessing you're recommending that for the divot though, right? Even if I did a complete circle, I get that segmented/interpolated effect.
Old 01-28-2008, 12:00 AM
Moderator
We don't know what type or quality of machine this is. It is possible for drive screw inaccuracies and/or drive screw bearing eccentricity (in the bearings) or intermittent stick/slip of the screw or slides to combine with excessive backlash and produce a wavy surface. The prime indicator of this would be waviness that is some multiple of the lead screw pitch.
Old 01-28-2008, 12:02 AM
Yes,that's the reason. And you have tried to do a complete circle and the same result?
Have you tried different feeds and speeds?
Stefan Vendin
  #11   Ban this user!
Old 01-28-2008, 12:26 AM
Okay, I can see that. But I'm thinking about a straight diagonal line. I should see this effect then too, unless both axes have the same problem and in sync with each other. I can run a test of that easily tomorrow. But with the backlash reduced/eliminated, you're suggesting I should not see this effect, right?
The mill is a converted (by someone else) ... HF geared-head mill. It's a bit larger than an X3. Conversion really being only the addition of stepper mounting plates and drive pullies/belts. I was planning to do a ballscrew conversion with some Roton screws, but with all my other electronic and automotive projects, I decided to just adjust this, reduce/eliminate backlash and run as is for now. Meanwhile, I keep my eyes peeled on ebay for an appropriate ballscrew. But I've barely begun to tweak it.
  #12   Ban this user!
Old 01-28-2008, 12:28 AM
dapoling is on a distinguished road
I have seen this before and it was bad ball screws.
As to the program using a G2 as others have said is not the problem but I would change your tool path to enter and exit part before feeding in Z.
Your feeds and speeds are fine, depending on the machine can be increased.
good luck
My Response to "It's Close Enough", "Is Your Tool Box and The Door Close Enough?"
What effect does microstepping have on torque? Stuff-Builder Stepper Motors and Drives 64 04-05-2012 04:43 AM
Hall Effect Chopper legomanww General Electronics Discussion 5 12-20-2007 02:11 AM
Hall Effect Limit & Zero Trebleplink General Electronics Discussion 3 10-19-2007 06:08 PM
guitar effect xfidelity Hobby Discussion 0 06-26-2007 06:19 AM
Cycle pause in effect? What? wildcat Mach Software (ArtSoft software) 0 12-02-2006 05:28 AM
