Old 01-25-2008, 10:19 AM
smellyfeet is on a distinguished road
My bits are dented
Hi all,
On night time running, my lathes are reliably churning out parts but that is where it all goes wrong. The parts are falling into a container with either de-watering fluid or water with wood floating on the top to break their fall then sinking to the bottom and denting other parts.
Does anyone here have a foolproof method of catching parts without the denting? I have tried different depths of container but so far have had no luck.
Any suggestions will be greatly appreciated.
Smelly....
Old 01-25-2008, 11:19 AM
keebler303 is on a distinguished road
you need something that will let the parts sink slowly. Something more viscous than water, like maybe 90 wt. gear oil or something. Corn syrup might work too but night get a bit sticky. Maybe something like jello would work if you got the consistency right. There are food thickeners whick thicken water up quite nicely.
Matt
Old 01-25-2008, 12:01 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
How about using diced up sponges?
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 01-25-2008, 01:53 PM
*Registered*
Mike Stevenson is on a distinguished road
The fool proof method is to remove each part after it has been parted off.
Old 01-25-2008, 02:18 PM
Sponges might work for a few, but what about 100? He needs something to catch them and then stack them gently. You could use some type of conveyor that would feed them onto a table or something where they were not piled on top of each other.
tough to do when you're running lights out.
Matt
Old 01-25-2008, 03:31 PM
mxtras's Avatar
Silver Member
Conveyor to a roller table.
Scott
Old 01-25-2008, 03:54 PM
HuFlungDung's Avatar
Moderator
How about some sort of a paddle wheel thingy on top of the bucket. The part falls into the top compartment, which renders the wheel out of balance, so then it rolls over and drops the part into the bucket (filled with water). Supposedly, if you kill off the initial energy the part acquires in free fall, then there won't be enough energy regained as it descends from almost zero speed at the top of the bucket.
Old 01-25-2008, 10:14 PM
*Registered User*
fpworks is on a distinguished road
I have a similar problem with our automatic bandsaw. Fortunately, they are not finished parts, but nonetheless, they do get nice dings that need to be hit with a file before going to a fixture in a machining center. It is quite a pain with production runs of over 1000 parts.
The solution that I have planned is to use a ramp in which the angle can be adjusted based on the mass of the part, and the height of the bottom of the ramp can be adjusted based on the current number of parts in the basket. Like Hu said, the idea is to absorb the energy between the machine and the box. In this plan, friction from the part sliding down the ramp would accomplish this.
Of course, this is just in planning, so I don't know the pitfalls yet. Hope to accomplish it soon. I look forward to hearing other suggestions here.
Old 01-25-2008, 11:39 PM
Something like Hu's suggestion with the blades on the paddlewheel made out of brushes; or the brush skirt like is used on the dust collector around router heads.
The ramp idea works; we have a lathe set up like that with a piece of rubber floor mat on a slope leading down to a plastic curtain and behind that is the coolant tank which the parts drop into.
Old 01-28-2008, 11:58 AM
Thanks for all your suggestions, I am going to try a modified version of the paddle wheel that will look more like one of those 1970s drinking flamingos.
We are also going to try cork chips.
I will let you know how I get on, but any more suggestions would be very welcome.
Smelly.
  #11   Ban this user!
Old 01-30-2008, 10:48 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Bath Tub full of porridge- cheap and bio degradeable and if you get hungry...
Or, what about loads of plastic spheres (like what my kid rolls about in at the Whacky Wharehouse)- depending on the size of the part you'd get away with that or table tennis balls if they're small parts (and not hot!). Big tub of dried peas if they're real small?
Use a big magnet to retreive the parts (assuming they're ferrous)?
Sorry if this is off the wall... been a long day
[Edit] Angle the container and make sure it touches the machine so that the vibration will "shake" all the components to one end of the tub[/Edit]
I love deadlines- I like the whooshing sound they make as they fly by.
  #12   Ban this user!
Old 02-18-2008, 08:45 AM
cncswiss1's Avatar
cncswiss1 is on a distinguished road
I've used heavy gear oil in the past and it works great, messy, but effective.
Bits teenrocketnerd DIY-CNC Router Table Machines 8 06-23-2007 10:30 PM
What bits to use becikeja WoodWorking 5 08-11-2006 10:27 AM
Where to buy bits hugo carradini DIY-CNC Router Table Machines 2 05-23-2006 06:52 AM
Show me the bits darth442 General Metalwork Discussion 0 05-18-2005 01:34 AM
Luv those little bits.. CRFultz DIY-CNC Router Table Machines 27 05-14-2005 05:41 AM
