I have read many questions from the CNCzone members regarding the cutting of Hardened and Case-Hardened steel rails, so here is a little post on how I do it! First off, I have a 6x12 Surface Grinder in my shop. A necessity if I do say so! They have a magnetic chuck, which allows for easy holding of steel parts and tools. For this job I used my old grinding vise, which I have rigged up a stop that's nothing more than a piece of pipe with a 1/4-20 threaded rod inside. This holds a little metal plate at a solid point, so all the rails will get cut the same length! The grinder has an abrasive cut-off wheel, which is around 3/32" thick. The grinder's RPM is around 3000+ and this will eat the steel really fast! For the sake of taking a movie, I have removed the safety guard from the grinder's spindle. Because the sparks and debris fly all over, I have safety goggles & a dust mask on! After all the parts were cut, I took them out of a bucket of coolant which was used to cool them off, and loaded them into my lathe where I face off the burn squaring up the end and bringing it to my desired length. Now, I know that the average bloke doesn't have a Surface Grinder, but an abrasive cut-off saw's are really inexpensive and come in a variety of sized. One person even mentioned that the local ACE Hardware store had one which they used to cut pipe! VIDEO (15.2 MB) |
| We have a linear dept. at work that supplies rails for cnc machines, most are about 10-15ft. long, we have a very large C/O saw to rough out the length, then turn/thread/chamfer to finish on the cnc. So it sounds like your doing what we do. Are you also turning the threads? I think the biggest thing for diy guys at home is they don't have a lathe. .
__________________ Free DXF Files - Vectorink.com - myDXF.blogspot.com |
| Hey Switch! Most of the rails I make are used out of the box, a few get blind holes drilled & tapped, and some get cut to length. All are 1/2" & 3/8" dia. Cutting long pieces in my grinder is a bit of a problem, as it only has a throat depth of 10" or so. That requires I cut on an angle, and then cut again to make it square. It's OK for a hobby shop! I agree most DIY people don't have lathes, I'd be lost without mine even if it is a Birmingham! Widgit
__________________ www.widgitmaster.com It's not what you take away, it's what you are left with that counts! |
| 1" Hardened linear rail | 2fst4u | CNC Plasma and Waterjet Machines | 2 | 11-06-2007 12:23 AM |
| Parting case-hardened rods, what utensils to use? | Deusrexmachina | General Material Machining Solutions | 12 | 10-24-2007 10:29 PM |
| Spot drilling case hardened steel | Zumba | General Metalwork Discussion | 20 | 03-04-2007 01:32 PM |
| 20MM Case Hardened or Bright Steel | simso | Linear and Rotary Motion | 5 | 12-28-2006 05:38 AM |
| Cutting linear rails | Cutloose | DIY-CNC Router Table Machines | 6 | 10-28-2005 06:42 PM |
