Old 01-21-2008, 07:00 AM
pp-TG is on a distinguished road
Burrs/threads
Hi All,
Any of you have a good rule of thumb when it comes to chamfers and threads? I am looking for a good rule that works good on chamfering threads to have no burr on the starting thread any help or ideas would be great.
Thanks, Travis
Old 01-21-2008, 07:54 AM
neilw20's Avatar
neilw20 is on a distinguished road
Cool Try this.
Put a 45 degree chamfer on the end of the thread.
Causes a nice vanishing thread, internal or scroll (flat).
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 01-21-2008, 08:00 AM
ghyman's Avatar
ghyman is on a distinguished road
45° works well, as does 30°.
I typically will start the chamfer at (MinorŲ - .005").
Not knowing your machine type, this may not apply: When single-point turning, I will always go back with the turning tool (after the threads have been cut) and re-cut the chamfer, followed by a final pass with the threading tool. This tends to remove the burr pretty effectively.
Old 01-21-2008, 08:36 AM
ghyman's way is the most thorough, if you want to go beyond this search for 'higbee'. This gives you a blunt start no burr thread, there have been several posts on it.
Old 01-21-2008, 09:05 AM
Thanks Guys,
I always end up with a crapy first thread very sharp and burry no matter what chamfer i put on I will try your suggestions.
Thanks again.
threads dgchumley G-Code Programing 7 03-13-2008 08:31 PM
ID Threads phoodieman Daewoo/Doosan 27 01-03-2008 08:33 PM
Need help with threads Turk88 General Metalwork Discussion 2 07-27-2006 01:35 PM
npt threads scubasteve G-Code Programing 13 03-16-2004 04:37 PM
Saving threads or parts of threads??? flybynight Forum Questions or Problems 4 02-22-2004 12:19 AM
