Old 01-18-2008, 11:11 PM
cnczoner is on a distinguished road
Tapping head?
I've been casually looking into tapping heads and wondering if they really work as simple and trouble-free as touted. I will generally need 4-40, 6-32 and 8-32, and many of those will be blind holes. Occassionally 10-32 and 1/4-20. I think a tapmatic 30x will handle this.
But is it really as simple as portrayed? Manually, I usually can't tap all the way thru aluminum in one pass, even if the hole is drilled all the way thru, without breaking the tap. So I generally tap a few turns, back out, wipe the chips off the channels in the tap, then continue tapping. An example is 8-32, 0.375" deep where I find that I need to clean the tap about 3 times.
Also, with my non-spindle-controlled milled, can I tap blind holes with one of these heads? I've not seen any feature that will stop the tapping head after a preset depth, etc.
Cheers,
-Neil.
Old 01-18-2008, 11:28 PM
You are maybe correct being dubious about using tapping heads with 4-40 or 6-32 in aluminum alloys. We do tap 8-32 through about 3/8" in aluminum successfully on a regular basis but 6-32 is not easy unless you drill the tapping hole for only a 65% thread and go with longer thread engagement. you do have to use a good tapping lubricant of course. 10-32 or 1/4-20 is quite simple.
Regarding tapping blind holes it is difficult to have really blind holes where the tap has to stop within a couple of turns from the bottom. Some of the tapping head have provision for a stop that contacts the workpiece so the drive will disengage at a set depth but there is some 'spring' in the mechanism so it is best to have some leeway, and of course you have to use a spiral flute tap.
Old 01-18-2008, 11:31 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Cheers,
-Neil.
I use a 30x TapMatic all the time, they are excellent tapping heads!
They have a torque adjust clutch, which can be gentle enough of an 0-80 or strong enough for a 1/14-20 tap!
The depth is controlled at the quill, and the tap will disengage when it reaches depth. When the quill is retracted, the tap reverses direction and it screws out! and you are now ready for another hole!
Tapping heads require either a spiral point tap or a roll form tap, the old 4-flute hand plug taps will not work at all.
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 01-19-2008, 12:37 AM
Hmmm... encouraging. I just need the correct taps/oils etc. So far I've been using home-depot hand taps with 10W-30 motor oil :-) Been meaning to try hope-depot's dark pipe threading oil.
My applications would be 1/4" or 3/8" alum plate that would need to have some mounting screws on the back for PCB's or securing the plate itself, without any screws or holes visible on the front. From 0.25", if we leave 0.050 inch of material, that leaves 0.20" to be drilled/tapped. At 32tpi, that's about 6 threads . Since a bottoming tap would leave a couple chamfered (unusable) threads at the end, that leaves about 4 usable threads which is fine. So it would work in theory, if the tapping head has good enough depth control for this.
IIRC, I'm pretty sure tapmatic has instructions on their website -- I should really read it before purchasing anything shouldn't I?
Cheers,
-Neil.
Old 01-19-2008, 09:53 AM
Regular motor oil is pretty much useless for tapping, or any metal cutting on most metals and totally useless on aluminum. Strangely enough Dexron ATF works very well. Kerosene also works well but smells.
But the best thing is get hold of some proper tapping fluid for whatever material you are working with.
Old 01-19-2008, 12:11 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Definitely get some Tap Magic EP Extra (designed for aluminum). Proper cutting fluid makes a world of difference. Dark threading oil is not good for your application.
Your other big issue is the taps you are using.
For blind holes get spiral flute MACHINE taps.
You will be shocked at the difference these 2 changes will make.
www.integratedmechanical.ca
Old 01-19-2008, 01:27 PM
neilw20's Avatar
neilw20 is on a distinguished road
Talking Tap Magic.
Tap Magic is really good.
We have no problem in Australia because metric taps are much finer pitch that your 6-32, 4-40, 8-32 etc. (LOL)
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Tapping head? Chuck Reamer Tormach PCNC 1 10-04-2007 10:39 PM
Tapping Head Preference? Otokoyama General Metalwork Discussion 4 01-04-2007 07:14 PM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 12:08 PM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 08:10 PM
Tapping head any good? kong General Metalwork Discussion 6 04-19-2005 03:49 PM
